The Wasteland.
Discussion in 'The Wood Pile' started by fishingpol, May 21, 2019.
  1. buZZsaw BRAD
    I wonder what firewood thinks about?
  2. T.Jeff Veal
    Good job, sir. Nice pile of splits
  3. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I found a log catcher for the DHT splitter on FB marketplace. Went and picked it up today and put it on the beam. Turns out this shelf is for the 22t, 27t and 35t.
    I have the 25t.:mad:Support arms are a little long and will need holes drilled in the shelf, but not a big deal. These shelves are tough to locate and this was NIB, so I just went and picked it up. Also the shelf will sit a little under the beam, not against the side.
    I guess the tags are important to read...
    A little bit under the beam, but I will be happy with it. It beats dropping the half-split round and picking it up again.
  4. T.Jeff Veal
    That will be a big help...
  5. fishingpol
    fishingpol
    Yes sir, it sure will.:yes:
  6. JCMC
    JCMC
    Just outside of Shushan, NY
    I have that on my 35ton DHT along with the table on the engine side works well.
  7. Erik B
    Erik B
    Western Wisconsin
    I still like my Work Mate bench set up by the splitter.
  8. fishingpol
    fishingpol
    I have my chop saw sitting on mine. Such a great bench.
  9. fishingpol
    fishingpol
    Every time I saw a pic of your splitter, i kept thinking about finding one.
  10. metalcuttr
    metalcuttr
    western WA
    Figure out what braces you need to make it exactly right and send me some sketches. I can cut and bend and send them to you.
    eatonpcat, buzz-saw, Chaz and 7 others like this.
  11. fishingpol
    fishingpol
    Thank you for the offer metalcuttr! I just have to drill two holes further out and I'll be in business. Nice offer though!:yes:
  12. metalcuttr
    metalcuttr
    western WA
    Glad it is an easy fix!:thumbs:
  13. fishingpol
    fishingpol
    After 2 1/2 days of rain, I decided to get the shelf installed. Two easy holes and I just have to locate my metric impact set.
    Also replaced the hydraulic fluid. The filter is NLA and I haven't found the equivalent cross reference yet. The filter that came with the machine is DHT branded with their part # on it. I just want a good brand name from a local store and not from Amazon.
  14. metalcuttr
    metalcuttr
    western WA
    My DHT 35Ton takes a NAPA gold 1551 Hyd filter that is a cross reference to the original DHT. A quick check on the DHT manual seems to indicate the same filter for 25 and 35 ton splitters. The NAPA 1551 is easily cross referenced to many filters (Fram, Baldwin, Fleetguard etc.).
  15. fishingpol
    fishingpol
    I did see that number on a net search. I think the microns was 15 for those bigger models. Mine is a 10 micron with a 15 gpm pump. There is a Napa not far from work, I'll have to grab one and thank you for checking.
  16. metalcuttr
    metalcuttr
    western WA
    My pleasure Sir!
  17. buzz-saw
    buzz-saw
    Ct.
    that’s what is great about this place.
    Help from others.
    Awesome!!
  18. buZZsaw BRAD
    X2 couldnt agree more!
  19. fishingpol
    fishingpol
    Dry air moved in with a good breeze this afternoon. I spent a little time working the cherry pile. The splitter worked fine with the changed fluids. Everything was just soaked and covered in dirt from the rain splashing. I can't wait to get at the EAB ash out back, but I have to process what is on the ground first.
    I took Holly out for a good ride to a local farm to get some eggs and check out the horses. No complaints from her.
  20. buZZsaw BRAD
    Nice day for it. Not humid with a nice breeze down here too. Nice work there FP!:thumbs:
