Butchery
Discussion in 'The Game Room' started by BCB, Jun 20, 2020.
  1. JackHammer
    JackHammer
    Yeah, there is an 80 qt scalding pot that loosens the feathers and then a plucker with about 80 rubber fingers that takes the feathers off. Plucking by hand takes 10+ minutes and plucking with the machine takes 20 seconds.
    Chaz, Chazsbetterhalf and Chvymn99 like this.
  2. jrider
    jrider
    Nice. I have a free standing plucking machine. It’s drum style. And I agree, Hand plucking is for the birds!
  3. Smokinpiney
    Smokinpiney
    "South" Jersey
    My search for a walk in cooler has finally ended. Over the last few years I had plans to build one or use a reefer box but it just hadn't happened yet. Yesterday i find out that a friend of ours who's moving to WV doesn't want to take his walk in with him and needs it gone so the house can get listed. I made a quick phone call and they said come get it, it's yours! :hair:. Dad and I went over this afternoon to load it up and bring it to it's new home.
    He was cooling it with a 5k btu window unit and coolbot. He kept the ac and coolbot for his next project in WV but I'm not complaining. Couldn't beat the price (free!). I can't wait to get this thing set next to the shop and ready to hang some deer this fall. Can you guys recommend a good roll on coating that I could apply to the floor for easy cleanup?
  4. jrider
    jrider
    Nice score Jeff. What kind of temps would it chill to?
    Chazsbetterhalf and metalcuttr like this.
  5. Smokinpiney
    Smokinpiney
    "South" Jersey
    Thanks joe. He said it would hold 40° consistently without a problem.
  6. BCB
    BCB
    USA
    Game changer for sure! Nice pick up.
  7. metalcuttr
    metalcuttr
    western WA
    I would be tempted to try a pickup bed liner product. Might be worth some investigation.
  8. Smokinpiney
    Smokinpiney
    "South" Jersey
    Got the window unit installed in the cooler today and gave it a test run in the 90° humid air. I don't have the coolbot controller yet but it brought the inside temp down from 85° to 60° in about 45mins.
    The previous owner had a casement window ac unit installed but i had a standard 8k btu unit laying around. So i cut the hole to size and framed the extra space in order attach sheet metal and insulate.
    It felt pretty good being in a 60° box on a day like today :D.
  9. BCB
    BCB
    USA
    Nice. Do you have this set up outside or in a garage?
    5 weeks from NJ early bow season opener!
    I took advantage of the cooler weather earlier this week and organized the garage so I could get to the reach in cooler. I still have to clean the cooler out and give it a test to make sure everything's working fine.
  10. Smokinpiney
    Smokinpiney
    "South" Jersey
    BCB it's outside but right at the back of my shop. I normally take deer in the back door to where i butcher them so this will give me the opportunity to let them hang as long as I want until I'm ready to butcher. Then it's just a few feet out of the cooler and into the shop.
    I was hoping to fit it inside but it's 3" too tall :(.
  11. Ronaldo
    Ronaldo
    Some painters plastic on the floor right under the critters would keep drippings contained for a temporary fix.
    Chazsbetterhalf and Smokinpiney like this.
  12. metalcuttr
    metalcuttr
    western WA
    You could just use a good concrete floor paint then use a couple of those 3'X3' galvanized drip pans for under your car. Put these right under the carcass. Added benefit is you can take the pans outside and hose them out!
  13. Smokinpiney
    Smokinpiney
    "South" Jersey
    And we're in business! Got the coolbot hooked up and gave it a test run. I still need to clean all the wiring up but I was too excited to test it. It brought the inside temp down from 81° to 38° (the temp i set the coolbot to) in about 2hrs. The compressor shut off like it should and the fan stayed on high to keep the coils from freezing up. It was an expensive little gadget but IMO well worth it. The temp rose a few degrees after i had the door open of course. Can't wait for bow season!
  14. jrider
    jrider
    You’re going to have some friends come bow season.
  15. BCB
    BCB
    USA
    Awesome! How big of an AC unit did you use?
  16. MikeInMa
    Nice beer fridge!! :salute::drunk:
    Chaz, Chvymn99, jrider and 3 others like this.
  17. Smokinpiney
    Smokinpiney
    "South" Jersey
    jrider haha definitely. You know where I'm at if you need to hang one.
    BCB i used an 8k frigidaire that I had laying around. Thankfully it gets the job done.
    MikeInMa lots and lots of beer! :drunk:
    Chaz, Chvymn99, jrider and 2 others like this.
  18. JackHammer
    JackHammer
    It's that time again! Put about 12 chickens in the freezer last weekend and will probably process another 13 or 14 tomorrow.
    I am real happy with the barred rock cockerals as meat birds. The are heritage breeds and still pretty chunky. The only complaint is that they are still fairly lean compared to the yearling birds with gobs of yellow delicious fat.
    This is pollo-loco. He is the biggest of the group and will keep him to be my new stud. Hopefully he makes it to the spring.
    The little hen there is a blue or green layer.
  19. Smokinpiney
    Smokinpiney
    "South" Jersey
    I was explaining to my 7yr old daughter that when we do eventually get chickens, some will be meat chickens, she says "not if I name them!"
    I said you can name them whatever you want but i'm still gonna chop their heads off. Her facial expression was priceless :eek::eek:o_Oo_O:(:(
  20. eatonpcat
    Let her name them, call one Paprikash the other Marsala, don't forget fried, grilled, cacciatore...lol
    huskihl, Smokinpiney, Chaz and 3 others like this.
