Hard to start Husqvarna
Discussion in 'Chainsaws and Power Equipment' started by Chud, May 19, 2021.
  1. Chud
    Chud
    I picked up a well traveled 272 and replaced missing and broken parts. When replacing the muffler I looked at the piston up and down and it looked mint. Throttle response and power feels like it should, but cold starts are a bear. Once it fires restarts are fine.
    Does it need a carb rebuild?
    I’ve had a few 2 series and they are not the easiest to get fired after sitting a while, but the 272 is beyond normal on # of pulls to fire.
    I did not replace the plug, should I start with that?
    The 371 pops off 2nd pull after sitting and feels light years ahead of the 272 in smooth cutting.
  2. WeldrDave
    I'm no great saw mechanic but I would start with the fuel filter in the tank. Now, I'm not sure if the Husky's have that like the stihls do but that sounds like my first look... :binoculars:
  3. metalcuttr
    metalcuttr
    western WA
    A n
    A new plug and correct gap can never be a bad thing! It is also a cheap start at troubleshooting.
    Husky Man, Ronaldo and M2theB like this.
  4. The Wood Wolverine
    Agree with above, plug and filters are a given. I'd definitely do a carb rebuild kit. They are relatively cheap and easy to install. Those diaphragms get old and firm. Sonic tank is best if you can.
    metalcuttr, Sandhillbilly and M2theB like this.
  5. M2theB
    M2theB
    Central Massachusetts
    Give her a tune up with new plug and filters. A carb clean and carb kit might not hurt either. see how that effects it and go from there.
    if that’s all complete and the issue remains, look for air leaks via pressure test or carb cleaner spray at idle. Pressure test is better info
  6. Ronaldo
    Ronaldo
    Yeah, the 3 series Huskies are a lot smoother than the 2 series, so that's normal. My 371 takes a lot of pulls if it hasn't been run for a month or so. I dont fight it, I just pop the top cover, pull the filter and give it a dribble of mix. It fires right up afterwards.
  7. Chud
    Chud
    Thanks for the feedback. I’ll start with plug and fuel filter. It already has new air filter on it.
    M2theB and The Wood Wolverine like this.
  8. Nixon
    Nixon
    West Sunbury,Pa .
    If it runs fine once started , I’d check the carb diaphragms for signs of aging . Maybe do a compression check .
    M2theB, Chud and brenndatomu like this.
  9. Chud
    Chud
    My 5 pack of fuel filters showed up today so I replaced the plug and filter. I should have taken a pic of the plug before I dropped it in my full shop can. The post came off with cap and the plug looked like the saw has been running lean. Here’s the filter after I wiped it once with a towel.
    The good news is the saw fired after 5 pulls with new plug and filter. Thanks again for the troubleshooting help.
    Nixon, Ron T, M2theB and 3 others like this.
