Englander 25-pdvc/55-shp10 elbow 90 degree vent pipe detached today
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by rjdb, Mar 15, 2021.
  1. rjdb
    rjdb
    Plaistow NH
    Obviously i'm not running it until I get this fixed, which is unfortunate because it's probably the last below freezing day we'll have this winter. For starters it was filled with ash, which I believe is the purpose for the elbow. So I'll have to check that as part of normal maintenance from now on.
    The vent pipe detached, looks like there was some sticky stuff holding it in. What is the standard protocol for fixing, is this a professional only job? Is the size the wrong for the pipe? I can put it back on, but it's barely held on. What do you guys recommend?
  2. rjdb
    rjdb
    Plaistow NH
    imacman likes this.
  3. Pete Zahria
    Pete Zahria
    New Hampster
    Are you saying that this piece was attached directly to the back of your stove??
    This is just a cleanout tee that can be placed between any two pieces of the vent pipe.
    Dan
    imacman likes this.
  4. rjdb
    rjdb
    Plaistow NH
    Yes that cleanout T was attached directly to my stove, I would like to do it the right way if I can. I ordered the second adapter piece.
    Is this a DIY job?
    imacman likes this.
  5. will711
    will711
    Pocono Mts.
    You need the stove adapter , which allows the vent pipe to then be attached to the stove and yes it's a DIY job .
    Rich250, Pete Zahria and imacman like this.
  6. Rich250
    Rich250
    Berks County PA.
    To do it correctly the new adapter should then be screwed to the stove with like 3 screws and make sure you seal it with hi temp sealer .
    imacman likes this.
  7. rjdb
    rjdb
    Plaistow NH
    I have the new adapter it works great! It fits perfectly. But what sealer would you recommend?
    CleanFire, Rich250 and imacman like this.
  8. imacman
    imacman
    Denver, NC
    Any HiTemp silicone 500* or higher
    RGrant, CleanFire and Rich250 like this.
  9. rjdb
    rjdb
    Plaistow NH
    Is this stuff good?
  10. imacman
    imacman
    Denver, NC
    Links to places like 'Zon no longer show up
  11. Pete Zahria
    Pete Zahria
    New Hampster
    whatdaya mean?
  12. Rich250
    Rich250
    Berks County PA.
    No that is cement and gets hard you want high temp silicone. Something like this.
    CleanFire likes this.
  13. imacman
    imacman
    Denver, NC
    Evidently, I'm not seeing the posted links and/or pics.
  14. Pete Zahria
    Pete Zahria
    New Hampster
    oh...
    imacman likes this.
  15. rjdb
    rjdb
    Plaistow NH
    Awesome, just bought it. I'll clean the joint really good then apply this stuff. Let it cure according to directions. I have about a dozen bags to burn before summer.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Pete, do you have enhanced tracking protection turned on in a browser as your default?
  17. imacman
    imacman
    Denver, NC
    If I do, and that's what's causing it to happen, it did it all by itself. One day I can see everything, the next nothing.....and I didn't changed any settings on anything. :loco: :crazy:
  18. rjdb
    rjdb
    Plaistow NH
    So I had a bunch of really bad bags of pellets. Jammed up my auger motor and finally burnt it up. Paid the stupid tax and switched out my auger motor. Not a moment too soon too.
    imacman and badbob like this.
  19. badbob
    badbob
    Been there,done that. Many years ago.
    imacman likes this.
  20. imacman
    imacman
    Denver, NC
    If your auger wouldn't break the pellets by itself, it was time for a new one anyway.
