Smoker build
Discussion in 'The Smokehouse' started by Greenstick, Nov 15, 2020.
  1. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    Did you paint the drum on the outside?
    I'm a wanna build one but the head office is balking. :loco: :crazy:
    Thinks the paint will burn off the outside.
    metalcuttr and Eric VW like this.
  2. eatonpcat
    Use high temp header paint??
  3. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    It's gotta be green. Stove bright has an emerald green that should work.
    I'll surprise her.:whistle:
    metalcuttr, Eric VW and eatonpcat like this.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    I've only used black acrylic enamel and built a dozen of them ...it will not burn off if your fire basket is the right size
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    IMG_1435.JPG i welded a little hook on the heat deflector so you can pick it out to service the fire if needed
  10. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    Thanks. You helped me get approval. Now she is searching for a free drum.:salute: I owe ya one.:coldone:
  11. Greenstick
    Greenstick
    I wish I had taken pictures as things went along but I have a tough time remembering my name let alone to document things. Got the old upright freezer and as time permitted have tinkered this summer converting and doing it as cheaply as possible. Ripped out all the cold making parts, chopped holes, made racks/hang poles, cannibalized a side burner from a shot gas grill, raided my "you are a junk hoarder" collection for pipe, angle iron, thermometers, and wood. Only parts bought so far is the self tappers and tin to skin over where the plastic was removed on the inside. I've read that a person should "season" it with a couple empty smoke sessions and it seems to work, curious though when it gets colder this fall how temps will run. Right now with it warm out, if I want to cold smoke I would need to take out propane and put an electric hot plate in because on my lowest setting on propane with as insulated as the freezer is it runs 225°. Any of you experienced fellers know what I can expect on my lowest propane setting when ambient temps get down into say the 20s, or since it is insulated will it still run 225°? 20210914_215554.jpg 20210914_214428.jpg 20210914_214905.jpg
  12. Greenstick
    Greenstick
    Teriyaki goose jerky, 1st time using the smoker!
  13. moresnow
    moresnow
    Goose jerky gets made here also. Often. Great eats. Enjoy.
    metalcuttr and SKEETER McCLUSKEY like this.
