Switched stoves ran into issues
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by kjeremy2, Mar 22, 2021.
  1. kjeremy2
    kjeremy2
    Copake Falls
    I went from a profile 20 to an englander 25PDVC and my foil tape is melting and I’ve never had a problem until now. It’s the same pipe and tape I’ve previously used for years now. Is it burning hotter than the previous stove? Tips? I attached pics of the stove and pipe thank you all in advance. IMG_0953.jpg
  2. stuckinthemuck
    stuckinthemuck
  3. brenndatomu
    Yeah that's not high temp foil tape...
  4. kjeremy2
    kjeremy2
    Copake Falls
    Any recommendations too correct the problem?
  5. Eric VW
  6. kjeremy2
    kjeremy2
    Copake Falls
    [mention]stuckinthemuck [/mention] yes that’s what was used.
  7. brenndatomu
    Getting the old stuff off may be a real trick though...
  8. kjeremy2
    kjeremy2
    Copake Falls
    It smells horrid so I hope I can get it off.
  9. brenndatomu
    Can't seem to edit my earlier post/link...
  10. brenndatomu
  11. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    That's the good stuff
  12. ttdberg
    ttdberg Pellet Pig
    CT
  13. kjeremy2
    kjeremy2
    Copake Falls
    I can’t see the photo for some reason. I was thinking of going to a plumbing and heating place and asking them if they had anything that would fit the bill.
  14. kjeremy2
    kjeremy2
    Copake Falls
  15. brenndatomu
  16. kjeremy2
    kjeremy2
    Copake Falls
  17. stuckinthemuck
    stuckinthemuck
    Make sure you fully remove the old stuff first. Don’t just go over the top. Gonna take some time with a razor blade and maybe some acetone for the adhesive..
    imacman and kjeremy2 like this.
  18. Lousyweather
    Lousyweather
    how about pipe which doesnt require tape?
  19. kjeremy2
    kjeremy2
    Copake Falls
    I have it but I don’t trust it 100% because I’m a fire fighter and i’m paranoid about carbon monoxide.
    Lousyweather and imacman like this.
  20. stuckinthemuck
    stuckinthemuck
    Did you do the exhaust pipe install yourself?
    Lousyweather likes this.
