Entry level saw recommendations
Discussion in 'Chainsaws and Power Equipment' started by mrfancyplants, Mar 1, 2021.
  1. JCMC
    JCMC
    Just outside of Shushan, NY
    Check with huskihl and see if the 6100 is still available.:saw:
  2. mrfancyplants
    mrfancyplants
    South Carolina
    I have a lead on CL on a echo cs-440 44cc. For $150, even with the broken chain break handle, this is a good deal on a solid step up for me right?
    Loon and buZZsaw BRAD like this.
  3. buZZsaw BRAD
    Im not well versed in Echo saws so i cant say. With a broken handle id say no. Did you and horkn touch base?
    amateur cutter and mrfancyplants like this.
  4. mrfancyplants
    mrfancyplants
    South Carolina
    I did get a message from him, but not a price yet. But esp w shipping and all, I don’t want to low-ball him and I think this one will be up my alley. I think I can get a metal replacement chain break lever pretty cheap.
    amateur cutter likes this.
  5. Warner
    Echo 15% off sale is coming up in a couple weeks. Buy something new, treat it well and you will have it for a long time.
  6. Loon
    Loon
    North of the border
    Had one of these for years mfp and it worked great.
    Till someone drove over it with a tractor? :zip: :coffee:
  7. buZZsaw BRAD
    X2.
    Buying used will save you money but you never know what is/could go wrong, Wait for the sale and get a nice new saw and you'll forever be happy when you go to cut. Not knowing Echo's, maybe someone here can recommend which model. Id go 45cc range. Easy enough to handle with enough power to cut bigger logs.
  8. Warner
    I personally would go with the cs590
  9. Eric VW
    Is the owner going to pull the muffler and show you the condition of the piston? Will he/she show you a compression gauge hooked up to it?
    That’s a big chance to take even if you consider $150 a good deal.
  10. Loon
    Loon
    North of the border
    :cheers:
  11. rdust
    rdust
    SE, Michigan
    My brother has a Rancher 455 with a 20” bar that does a decent job and a buddy has the 60cc Echo pulling a 20” bar with a modded muffler that’s pretty decent. My 361 out cuts the Rancher probably two cuts to one, the Echo does a little better. I consider them both nice starter saws.
    I’m a pro saw guy but understand it’s not for everybody. They cost more but there is a reason for that.
  12. mrfancyplants
    mrfancyplants
    South Carolina
    I pulled the trigger on the cs-440. I appreciate the input, and you have fully claimed the right to say “I told you so,” if the saw has major issues.
    It started up after a few pulls and ran a little rough and smokey, but my free ryobi does that cold too. The chain was spinning and that was about it for my testing.
    The guy says they got it for a tree in the backyard and never used it again.. wasn’t sure how the chainbrake lever broke. It looks like the chain was used a few times and never sharpened.
  13. JCMC
    JCMC
    Congrats! Hope it serves you well for many years.
    Loon, mat60 and mrfancyplants like this.
  14. Chud
    Chud
    Looks like it got crushed by something or took a hard drop. Hope you get years of good service from it.
    Husky Man, Loon and mrfancyplants like this.
  15. Husky Man
    Husky Man
    Mt Hood Oregon
    14”, .325/.050 Full Skip ;):rofl: :lol:
    Doug :cheers:
    mrfancyplants and Loon like this.
  16. Husky Man
    Husky Man
    Mt Hood Oregon
    Not likely to walk into an Ace Hardware, and find an 18”, 3/8, .050 Full Skip, in a Clamshell package hanging on a hook, but a Decent Dealer should have a spool of Full Skip and be able to spin you a loop or two or three ;)
    Doug :cheers:
    Loon, buZZsaw BRAD and mrfancyplants like this.
  17. buZZsaw BRAD
    One of the advantages of doing business with a good OPE dealer!
    Sandhillbilly, Husky Man and Loon like this.
  18. mrfancyplants
    mrfancyplants
    South Carolina
    Sorry buZZsaw BRAD I guess I was looking for a steal of a deal, not a stihl of a deal ;).
    You can say “I told you so” if it doesn’t work out.
    assuming the compression is decent, how much bar do you think it could power with a skip tooth chain? It is rated for 16-20”
    Not for standard use, but just in case I run into some big logs.
  19. buZZsaw BRAD
    No worries. I hope it serves you well. What size bar does it have? A 16" can cut a lot of average sized wood. I suppose a 20" even with standard full comp teeth will cut just not fast and you wont be able to lean into the cut. I learned that with my MS290 when i got a 20" bar and cut big wood.
    mrfancyplants, mat60 and Loon like this.
  20. buZZsaw BRAD
    :p
