And on the other burner... convert older 034 to adjustable oiler?
Discussion in 'Chainsaws and Power Equipment' started by Jon1270, Jul 24, 2014.
  1. Jon1270
    Jon1270
    Pittsburgh, PA
    My other active project is an older 034 I picked up a week or so ago. It had suffered a clutch failure that took out the original oil pump. Our own BuckthornBonnie helped me out with a replacement pump, but it's adjustable whereas the original was not, and the crankcase isn't made for it. It looks like I'd end up having to grind a pretty big hole in the case to make room for the adjuster, which I am hesitant to do unless there's good reason for it. Does anyone have experience with the non-adjustable oiler on this model, i.e. how well it performs? Or, have you done the conversion and can you tell me how it worked out?
  2. MasterMech
    I haven't run mine in so long that I can't remember. :confused::(
  3. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    One of my 034s doesn't have the adjustable oiler. I don't use that one too much, but I know that the oiler does a fine job when everything is cleaned up and fit properly.
    If needed, feel free to send that pump back or keep it ... up to you.
    You could grind away on that case if you're up to it--- there's probably a chance of weakening that area, but I know it can be done.
    I'm assuming the price of a new pump wouldn't be worth it, right?
  4. Jon1270
    Jon1270
    Pittsburgh, PA
    Thanks, very kind offer but I may use it yet. I'm sure I could pick up a used non-adjustable pump on eBay without too much trouble, so the cost of new isn't really the issue.
    AS has surprisingly little to say on the topic. The gist of it seems to be that the non-adjustable oiler is basically at full blast all the time, and the adjustable pump gives you the option to dial it down. I also saw comments worrying about weakening the case, but didn't see any accounts of cases cracking because of this. I'll stare at it for a while until one choice or the other makes sense to me.
  5. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Ok man, sounds good. Seems that you have a nice 4-hour ride tomorrow to ponder things like this... good luck!
    Chvymn99 and Jon1270 like this.
  6. DexterDay
    I would crank the adjustable oiler to the max setting and just slap it on..
    My Pennies. . :)
    Looking forward to your thread tomorrow on the 262xp. . :thumbs:
  7. Jon1270
    Jon1270
    Pittsburgh, PA
    Would be nice, but it's not possible. The crankcase casting is shaped a little differently, so the adjustable oiler won't fit without removing some magnesium.
  8. DexterDay
    Well, if the Pro cases and later cases didn't have the material there? Then why would it hurt?
    I'd get my Dremel and a good bit out and get to grinding.
    It's only a small section? As stated above? If it didn't hurt the cases that were casted that way? Why would it hurt one ground that way?
    Any pics? I don't even own an 036/034 anymore (what a shame) :(
  9. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Good point on the cases, Dex. I'd say grind away!
    Ebay has what looks to be the non-adjustable for $22...
  10. Jon1270
    Jon1270
    Pittsburgh, PA
    I put the adjustable pump in as close as I could get it and traced around the projection that gets in the way with a magic marker. The hole wouldn't have to be quite so large, but you get the idea:
    The hole for the oiler might end up merging with that rectangular cored-through hole in the original casting, and the combined void might look big even if it doesn't compromise anything meaningful.
    Chvymn99 likes this.
  11. Jon1270
    Jon1270
    Pittsburgh, PA
    Ya convinced me. Easy access from below, full range of adjustment:
  12. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
  13. Jon1270
    Jon1270
    Pittsburgh, PA
    Thank you very much. It's neat what you can do with a drill, a Dremel, a sharp burr and a couple of chainsaw files. The necessary opening is right up against a rib that you can sorta see in the pic taken from the bottom, but doesn't cut into it. I don't think it's a structural problem at all.
    I just got the saw all back together, so I should be able to try it out later today.
    DexterDay, Chvymn99 and MasterMech like this.
  14. Jon1270
    Jon1270
    Pittsburgh, PA
    Hey, I just realized that this is my first saw "mod." Everything else I've done has been aimed at restoring them to stock. Guess it's a special day.
  15. rookie1
    rookie1
    Nice work. :)
  16. Woodporn
    Woodporn
    S. MA
    Nice work Jon,
    Now in your spare time :rofl: :lol:, devise a way to make that OEM oiler adjustable.
    Jon1270 likes this.
  17. Chvymn99
    That's just like my 034. I guess, when it gets back from Tennessee, I'll have to check it out if it has a adjustable oiler or not. Great Pics...:thumbs:
  18. Jon1270
    Jon1270
    Pittsburgh, PA
    My current understanding is that most 034's did have adjustable oilers, and it's only the earlier ones that don't. This one also has the rarer 2-part brake mechanism dust covers, and a side-access chain adjuster. And it stands out in one other respect...
    Chvymn99 and DexterDay like this.
  19. DexterDay
    Whoa!! 180! Can you see a gasket on there? That should be a good runner.
    Is it open port or closed port cylinder? I just learned from MM that they made a CP cylinder for the 034. The 2 I did were both open port. The last one turned into an 036 before it left here. It's now a part of Swags line up. That was a good running saw as well.
  20. Jon1270
    Jon1270
    Pittsburgh, PA
    Base gasket is present. I'm having a tough time seeing whether it's open or closed-port. Any tips on that? Can you tell by looking at the outside of the cylinder?
    DexterDay likes this.
