Stack Depth
Discussion in 'The Wood Pile' started by Timbers Logging, Feb 1, 2021.
  1. theburtman
    theburtman
    I use pallets on top of stacks. It ties the stacks together and creates an airspace between tarp and firewood.
    Road-side Oak likes this.
  2. Warner
    Good idea, the warden won’t allow tarps here.
    PA Mountain Man likes this.
  3. stuckinthemuck
    stuckinthemuck
    1 use 1” diameter branches to tie the two sides together about 1/3 of the way up my stacks. I cut them 36-40” in length. I also use plastic tie straps to tie the cribbed ends back into the stacks using a staple gun.
    Softwood, theburtman and Stinny like this.
  4. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    Laughing!
    23 posts so far on stacking wood.
    We have a problem. (More than one if you listen to my wife.)
    I was building another woodshed this year and still may but I’m thinking I’ll try incorporate the ideas here for the first bits.
    Thanks to the original poster for bringing this up!
  5. rdust
    rdust
    SE, Michigan
    Usually I stack shoulder height on cinder blocks and 2x4’s or landscape timber’s. The stacks do tend to want to fall, I find the spring thaw causes a lot of movement. I do stack maintenance where I’ll use a floor jack to level then back out before they fall. I still will lose one on occasion.
  6. Erik B
    Erik B
    Western Wisconsin
    I just started doing this with my outside stacks this past summer. So far, so good.
    Thor and Eric Wanderweg like this.
  7. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    Hey, this is highly technical stuff that the ignorant layman just can't appreciate!:D
    Softwood likes this.
