stihl 025
Discussion in 'Chainsaws and Power Equipment' started by rusty ranger 44, Jan 31, 2021.
  1. rusty ranger 44
    rusty ranger 44
    south central Pa
    To All the chainsaw Wizards. Last summer I picked up a Stihl 025 from a yard sale and went to start it last week. The saw will start and run, however very high speed (seems like an air leak to me) sprayed carburetor cleaner around the clutch side,intake boot,carburetor , practically all over the saw with no change on the high speed. Also checked the piston for scoring which there was none. What am I missing here.
    M2theB likes this.
  2. M2theB
    M2theB
    Central Massachusetts
    You mean high speed at idle?
    Good troubleshooting start.
    Have you tried to turn the idle down on the carb, if that’s where it’s running fast?
    Counter clockwise.
  3. Chud
    Chud
    Does a counterclockwise turn on the H change anything?
    M2theB and The Wood Wolverine like this.
  4. The Wood Wolverine
    So you start it and it runs away at high rpm w/ no real idle?
    M2theB likes this.
  5. The Wood Wolverine
    One way I check for air leaks, take an old inner tube and cut pieces of rubber big enough to block behind the carb and behind the muffler. Then I converted an air hose nipple and an old broken plug. Apply some(light) pressure and spray soapy water, look for bubbles (make sure the piston is below ports).
    M2theB likes this.
  6. rusty ranger 44
    rusty ranger 44
    south central Pa
    changing the carburetor does not change the high speed idle. i did not want to run it very much, afraid of a lean seize
  7. Czed
    Czed
    Wv
    Adjust the idle speed until the chain spin stops
    Then turn the saw over to see if it surges or dies.
