Joining the Pellethood?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Gary_602z, Feb 1, 2014.
  1. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Thanks Dex that is what I like to hear!
    Gary
  2. DexterDay
    My first stove was a Quadrafire Classic Bay 1200 (47,500 BTU), and I ran it for about a half of a decade. Great stove and 90% of the time, I kept it on low. Quads are very efficient, and it seems that the E2 is the most efficient model they have made to date. I believe that the E2 uses some of the same technology that the Harman do (varying the blower out to match and maintain temp). If that's the case? Then they hit a home run with that stove. Looks great, heats great, and built to last.
  3. will711
    will711
    Pocono Mts.
    Eaton cat also has a Mt Vernon insert M55 he's a good guy :thumbs: won't steer you wrong :)
    eatonpcat likes this.
  4. savemoney
    Welcome Gary, I struggled with what to do about my zero clearance fireplace to the point I think I was making others sick hearing about it, but there are inserts designed to fit into fake fire place boxes such as imacman is showing in response #9.
    Basically, the installers told me they would destroy the zero clearance fire box and maintain the façade of the fireplace. They can go out the back wall of your fireplace or up and out the existing chimney with both the OAK and exhaust. Lots of options of where to put the OAK. I am not a roof climber so out the side would have been best for me. In the end, I just installed a free standing unit in another area and am exceptionally pleased with the results. What was important is that I got a lot of solid advise here. After 4 years of going back and forth, I make the change. Slow learner, but better late than never. Get someone over that is experienced to look at your situation. Good luck and welcome to the group. keep the pics coming!
    Larry
    will711 likes this.
  5. Lousyweather
    Lousyweather
    don't blow yer exhaust under the roof of the porch.......probs either gonna have to go thru the porch roof or extend out past the porch (which will look funny, as well as likely being over the 4' max horizontal run usually allowed)
  6. Gary_602z
    Gary_602z
    Definitely going straight up the existing chase in the old chimney. Think I will pull the trigger on this today or tomorrow! I see TSC has Pro-Pellets for 189.00 on an early order, should I just get 3 ton or try some different brands to see what I like better? I kinda wanted to have 2-3 on hand in the garage and then maybe experiment with some different brands.
    Gary
    savemoney likes this.
  7. mithesaint
    mithesaint
    NW Ohio
    Pro pellets for $189? Go for it. Those were some of the best pellets I've burned, and even if they're not great in your stove, $189 is still a pretty solid deal, even if they're only shoulder pellets. Get the 3 tons if you have the spare cash and room to store them.
  8. DexterDay
    For $189, I would jump on as much as I could afford. Pro Pellets are a very good pellet.
  9. Lousyweather
    Lousyweather
    Ive no experience with Pro Pellets, so cant comment, although given what we pay in the East, I say those are darn good prices! I am more a try a plethora of different choices kinda guy tho......nothing ventured, nothing gained!
    You mentioned using the old chase....what kind of pipe are you using for the exhaust work? If it's a wood chase, should be regular liner....not rated for clearance to combustibles......
  10. Gary_602z
    Gary_602z
    Ordered the Mt.Vernon E2 insert today!! Scheduled to be installed Aug 18th. Won't the wifey be surprised!:rofl: :lol::rofl: :lol:
    Gary
  11. savemoney
    That is an impressive looking unit. Hope it is everything you anticipate. Lots of folks here to help you with your questions. :thumbs:
    IHATEPROPANE likes this.
  12. DexterDay
    I think you will be thoroughly impressed.
    One of the best things you can do, and to get the best results from an insert, is to install good block off plates. Both at the stove level and at the top of the chase.
    The next best thing is to install an OAK. Almost every pellet stoves exhaust blower is blowing 80 CFM of air out the house. 80 Cubic Feet a Minute! So instead of throwing the air you already paid to heat, out the flue. Use an OAK and it will allow the heat to get deeper into your home, and stop and cold drafts from air being replaced in your home.
    Selkirk makes a vent set up called DT (Direct Temp). It has the intake and the exhaust all in one package. The OAK air is preheated by the exhaust pipe and helps dry any moisture in the air. Depending on what kind of flue is installed will depend on whether you can run up the existing chase, or if that vent will need to come down.
    Good luck and keep us updated with pics and such :)
  13. jtakeman
    Congrats!
    Your gonna post a pic so we can all drool right? ;)
    DexterDay, smoke show and will711 like this.
  14. smoke show
    smoke show
    Pittsfield, Wi
    Wait til Jay hears you didn't buy a Enviro... :eek: :whistle::popcorn:
    DexterDay, will711 and jtakeman like this.
  15. jtakeman
    Whether it was the M55 or the Mt V is good by me. 52i would also be a good choice, But hard to beat an auto clean or self cleaner for looooonnnnnggg runs in the cold season. ;)
  16. savemoney
    All good stoves, of course now that I'm a "convert" to Harman, I would point you in that direction. They are pricey, but they seldom disappoint the owners. One of the arguments about stove selection is the ability to get dependable advice and service. My old stove company wanted nothing to do with customers and always referred back to a dealer. Sometimes these dealers were furniture salespeople!
    Lousyweather likes this.
  17. Gary_602z
    Gary_602z
    Well we are still on schedule for installation on Monday!:thumbs::thumbs: With the cooler nights lately I am getting pumped.
    Gary
    slvrblkk, will711 and smoke show like this.
  18. will711
    will711
    Pocono Mts.
    I
    It's like waiting for Santa :D
    eatonpcat and Gary_602z like this.
  19. Gary_602z
    Gary_602z
    But Santa is Real! I have pictures of him!:rofl: :lol:
    Gary
    eatonpcat and will711 like this.
  20. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I think you'll love that stove. So far we've had one on the showroom floor for a little over a month and I honestly like the simplicity of it over the AE.
    Also have installed 2 for customers in the high country that are already burning and they are happy as could be.
    Keep it clean and read the entire owners manual and it will treat you well.
    Gary_602z likes this.
