My Drolet HT3000 thread
Discussion in 'Modern EPA Stoves and Fireplaces' started by Warner, Dec 25, 2020.
  1. brenndatomu
    Good point...get it...point...:whistle: :picard: :rofl: :lol:
    That is true though...
  2. Hoytman
    Hoytman
    OH
    Learn something every day...if you try hard enough. I did not know that. I just recently bought a moisture meter...el cheapo.
    T.Jeff Veal and yooperdave like this.
  3. Sinngetreu
    Sinngetreu
    North Central Iowa
    I was thinking that too. It's been a while since I used one though. Glad to re-confirm.
    The General MM is a common one, but I always wondered about it. The chart on the back seems a bit optimistic.
  4. Sinngetreu
    Sinngetreu
    North Central Iowa
    :picard:
    yooperdave and brenndatomu like this.
  5. Warner
    This was a fresh split at stove room temp. I’ll split another and check with the grain when people wake up.
    yooperdave, moresnow and Eric VW like this.
  6. Warner
    C4D2E14D-48F6-4DBB-A1B0-099E1CE17D1D.jpeg 1164DB81-77FD-4D22-B171-B6F5AA19CB16.jpeg 362F5F11-E558-461F-867C-7E82EB7F0833.jpeg Three readings on a fresh split stove room face with the grain. I leaned against it to get the probes in.
    This wood was split and stacked outside for possibly a year. It was then brought into the basement where it was basically kiln dried by the beast that is about 6 feet away from the stack. I run a fan on the wood stack when stove wasn’t going.
    fishingpol, Eric VW, Marvin and 3 others like this.
  7. Warner
  8. Hoytman
    Hoytman
    OH
    That might explain it. For posterity’s sake, grab a split and split it again and take another reading or three. Had that oak been outside I would say that doing the above would yield different and wetter readings, but given your stack is near the stove and you have a fan on it, then it may just be that dry all the way thru a piece of wood. If so, you’re on to something...stick with it.
    As small as your pieces are I don’t expect to see much change given where your stack is, then again I’ve been surprised before.
  9. Warner
    940497D3-A80D-4DAC-931F-E4FA4E31B968.jpeg Small pieces?
  10. yooperdave
    Warner ........... I don't quite know how to approach you on this matter, but do you think it is possible for me to maybe rent some of that space in your basement to help dry my wood? How much room do you have? What are your rates for space rental? :rofl: :lol:
    I do use larger pieces for my indoor stoves also, but the OWB chunks are lucky to get split at all. If I can lift them, they stay unsplit.
    You have a good system there for yourself, keep it up!! :handshake:
  11. oldspark
    oldspark
    NW Iowa
    Makes no difference on mine what so ever, works well and the readings are the same no matter how you stick it.
    Hoytman and T.Jeff Veal like this.
  12. Sinngetreu
    Sinngetreu
    North Central Iowa
    This picture is perfect for making a meme. I envisioned the caption "Ok, who's next?".
    That's a great set up though.
    T.Jeff Veal, brenndatomu and Warner like this.
  13. Eric VW
    That’s a stoopid amount of wood in front of the stove...
    I love it!!!! :salute::D
  14. Warner
    Sure you could bring some wood over. You can play with the slide. 6BCF6DD3-50A7-44C3-B954-A6BB03892742.jpeg
    T.Jeff Veal, c hardy, Thor and 7 others like this.
  15. Warner
    C3A45EFE-43AB-4299-8840-0517D698F09C.jpeg This was the start of the season. I don’t care much for going out in the snow, ice, wind, wet to fetch firewood.
    T.Jeff Veal, c hardy, Thor and 9 others like this.
  16. oldspark
    oldspark
    NW Iowa
    Used to be a guy on Hearth called Battenkiller and he documented how fast he could dry wood with a fan in a basement where the wood stove was, it's amazing how fast you can dry it down in those type of conditions.
  17. Warner
    I never really checked moisture content before. Maybe a couple times when splitting.
    This is the way my dad did it in this house when I was growing up. I’ll keep checking as I work down the pile. I’m pretty surprised at the readings. I was on the one year plan when this wood was split.
    T.Jeff Veal, Thor, yooperdave and 2 others like this.
  18. Eckie
    Eckie
    Wow that's a lot of wood inside! Is it just one row deep? Curious, do you ever have problems with bugs/insects?
    T.Jeff Veal, brenndatomu and Hoytman like this.
  19. Hoytman
    Hoytman
    OH
    Holy Smokes!!! I can tell he likes spiders and insects. :D:rofl: :lol: A little ortho max along the front on the floor, the walls, and insects don’t stand a chance.
    I have to admit that is beautiful.
    T.Jeff Veal and brenndatomu like this.
  20. Hoytman
    Hoytman
    OH
    In all seriousness...
    Warner I hope you burn most of that each year. That could present a serious fire hazard from anything...electrical fire or anything. Just be careful. We like having you around here. If nothing else to stir up crap about using stoves in ice fishing shanties.:rofl: :lol:
    ( I think that was you.) Ice reports I am getting from a friend in MI are horrible. Little ice where normally there is a lot...and I’ve been hoping to meet up with a friend for my first trip ever on ice.
    T.Jeff Veal and Eckie like this.
