Found At The Salvage Yard
Discussion in 'Axes, Mauls, and Hand Saws' started by JotulYokel, Dec 23, 2020.
  1. JotulYokel
    JotulYokel
    Missouri
    $3 at the salvage yard got me this. I'm having trouble getting the handle out tho. Any suggestions?
  2. MikeInMa
    Nice find!
    Cut it short. Drill down the middle. Chip it out.
    Not knowing any better, that's how I'd approach it.
  3. Meche_03
    Meche_03
    Missouri
    Nice find. On some of them there is a nail or spike under the swing hook. Unbolt the hook and see if there is a nail holding the handle in...keeping it from rotating. Might be just behind the hook.
    If you can not pull the nail, drill it out with a drill bit but stop as soon as you drill through the head. You should end up with a washer stuck on the drill bit that used to be a nail head. Then just take a punch and tap the nail in a bit further so it clears the metal collar.
  4. savemoney
    That is how I would do it. Should only take a couple minutes Nice find.
  5. JB Sawman
    JB Sawman
    pennsylvania
    Once you get the handle out Peavey Mfg in Maine will have a replacement handle JB
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Nice find. I like the foot on that one It would be real handy around here.
  7. JotulYokel
    JotulYokel
    Missouri
    Got it out. I just kept drilling with a 7/16ths long drill bit, and whacking on the other end with a big, long bolt. Eventually it came out. My local farm supply store had a handle. I'll paint the steel parts orange at some point, but right now, I'm gonna go cut some farwood.
  8. JotulYokel
    JotulYokel
    Missouri
    Found a handle at the local farm supply store yesterday, knocked it in place, and used it for the first time. Works great. The log I was working on was only 8 feet long, but 30" in diameter, and I could roll it over with ease.
    RIburn, Yawner, Midwinter and 13 others like this.
  9. JotulYokel
    JotulYokel
    Missouri
    When the weather warms up, I'll paint the metal orange so I can't run over it with the tractor while I'm in the woods.
  10. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    If you paint it white first . Then orange it will be much brighter.
  11. JotulYokel
    JotulYokel
    Missouri
    Hey, thanks CTF, that's a good idea.
  12. JotulYokel
    JotulYokel
    Missouri
    I used it on another tree yesterday. I love this thing. It's SO MUCH easier than trying to lift one end of a 10 foot log, while attempting to kick a piece of cutoff under it so I don't cut into the ground with my saw.
  13. Cold Trigger Finger
    Cold Trigger Finger
    I use mine when unloading sawlogs off my car hauler trailer. I can get an end up high enough to get a skid under it so it will clear the fenders.
  14. The Wood Wolverine
  15. metalcuttr
    metalcuttr
    western WA
    I have two of that general design. I left the stand on one for lifting smaller logs of the ground but removed the stand from the other to use as a peavey. I like them both. Glad you got the handle out ok!
  16. savemoney
    Also some wood preservative on the handle. My tools last a lot longer when I keep the wood painted. I like to paint them yellow so I can see them easily.
    metalcuttr, WeldrDave and M2theB like this.
  17. JB Sawman
    JB Sawman
    pennsylvania
    Usually the bright color paint looks good as you see it when you run it over :DJB
  18. JotulYokel
    JotulYokel
    Missouri
    Tell me about it! I somehow managed to run over a shiny, stainless-steel, hand sprayer with my tractor some years ago. I just mashed the top down a little bit--it still sprays, but looks like a drunken R2D2.
