No Pellet Winter
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by chbryson, Nov 23, 2020.
  1. eatonpcat
    Stupid question, but how do you get the pellets in the silo?? Sounds like a great system
    ivanhoe, slvrblkk and imacman like this.
  2. Mr Brick
    Mr Brick
    Nh
    They have trucks with augers that deliver bulk pellets, they'll drive right up and offload them into your container. I haven't been able to nail down pricing, but apparently it's cheaper fuel wise, so if you're already building it should be cheaper on the long run.
  3. Pete Zahria
    Pete Zahria
    New Hampster
    Slide off an old swingset..
    Dan
  4. don2222
    don2222
    Salem NH
    Does that slide work in reverse to bring up to the stove?
  5. Pete Zahria
    Pete Zahria
    New Hampster
    Stove is in the basement.........
    :yes:
    Dan
    imacman, ivanhoe, MikeInMa and 4 others like this.
  6. don2222
    don2222
    Salem NH
    That is the best way. :)
  7. badbob
    badbob
    Quite some years ago,south of me,wealthier people got into pellet boilers.Colorado springs area.Pellets were delivered in a bulk truck,and gravity fed(mostly) to the furnaces.BUT, not a stove!Was quite popular,down there,a while back.
  8. Lousyweather
    Lousyweather
    unfortunately, the folks who have trucks and do those deliveries aren't that common.....and you likely wont have the advantage of choosing different brands
    imacman and ivanhoe like this.
  9. Dr.Faustus
    Dr.Faustus
    Hudson Valley
    Us too, first year in a long long time we wont be relying solely on pellets. For many years we didnt even have a furnace. Last year we went solar, and this year had installed a whole house ducted heat pump. Our plan is to mainly use the pellets, and to either use the units "fan" function to distribute the heat better or set the heat pump slightly behind the pellet stove temp so it only kicks on if the stove 1. cant keep up or 2. decides to error out in the middle of the night.
    bogieb, ivanhoe, PelletHound and 2 others like this.
