XXV-TC question
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Pete Zahria, Dec 1, 2020.
  1. Pete Zahria
    Pete Zahria
    New Hampster
    Okay here is the deal.
    I have not seen the stove, nor will I, more than likely.
    Asking for a pellet customer.
    He says the stove tech is booked until January.
    He is getting an open door error, and of course the stove will not start.
    He says the switch on the hopper seems to engage, and the door gasket seems good.
    The stove was new last season, and has really not been used that much.
    Thoughts?
    Dan
    CleanFire and M2theB like this.
  2. M2theB
    M2theB
    Central Massachusetts
    open contact
    Get the CWD from the manual and a multi meter to check continuity.
    CleanFire and PelletHound like this.
  3. imacman
    imacman
    Denver, NC
    CleanFire likes this.
  4. bogieb
    Check to make sure the ash pan door is closed - as in physically open and re-close it. Check the fines box cover is on tightly. Ensure the cover for the igniter chamber is closed. Other than that, I got nothing. I would nt expect door gaskets to go bad in 1 season.
    Looked at the manual and it looks like it has way too many electronics for me - could be the brains got scrambled - try unplug, wait a couple of minutes, then re plug in.
    CleanFire and Rich250 like this.
  5. Rich250
    Rich250
    Berks County PA.
    If none of the above helps next would be try jumping the vacuum switch. Also have they tried running the diagnostics on it.
  6. Pete Zahria
    Pete Zahria
    New Hampster
    Like I said, I have not seen the stove, and probly will not.
    It is a friend of Henry's, he will probly take a run over ..
    But I am thinking, where it is a pretty new stove,
    it is not a gasket issue, and I agree it is probly a vacuum issue.
    Would be good to get a new pressure switch to have one
    on hand, 20 bucks, as there are several of us locally (pellet customers)
    that have Harmans.. it is always good to be able to tell people
    what worked for us, on similar problems..
    Thanks, Dan
    CleanFire, Ssyko and bogieb like this.
  7. badbob
    badbob
    Whenever I hear--"has really not been used that much." usually turns out to be a dirty stove or flue.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Isn't that he truth!!!
  9. eatonpcat
    Have him uninstall it and trade it in for a good stove...Hmmm maybe a one year old Enviro would still function!!
    CleanFire, bogieb, imacman and 5 others like this.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    He needs a USSC stove Bear running for his cave. >>>>>>>
    CleanFire, bogieb, eatonpcat and 6 others like this.
  11. badbob
    badbob
    Bears can be shot in their caves,in some states! o_O
    CleanFire, jtakeman, bogieb and 4 others like this.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Not Bear season, that ended last Saturday. It is always Bear hunter season in my cave.
    CleanFire, jtakeman, slvrblkk and 4 others like this.
  13. Lousyweather
    Lousyweather
    so, the "open door" is actually the vac switch detecting inadequate vacuum......the 2 blink error in newer, analog Harmans, circuit board E revision and later. This can be ALOT of things, many mentioned above....gaskets, fines cover, blockages, vac hose loose, bad vac switch, even the spark arrestor outside clogged. The vac switch is RARELY the issue.....but they can fail.....in situations where folks think its the switch, 9*% of the time or so, its something else.
  14. Pete Zahria
    Pete Zahria
    New Hampster
    Just a follow up...
    It seems like the end of his exhaust pipe has a screen, and it was pretty clogged up..
    Seems to be running fine now!
    I asked if he was certain that the path was clear...
    He checked... voila..
    Dan.
    imacman, bogieb, ttdberg and 3 others like this.
  15. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Bing, bing we have a winner.
    imacman, holstein, bogieb and 2 others like this.
  16. Lousyweather
    Lousyweather
    not to be a nitpicker, but I did mention the spark arrestor:
    youd be shocked and amused at the look of dismay when you brush that devil off and the stove immediately starts running perfectly......."that'll be $189 please...."
    :jaw:
  17. CleanFire
    CleanFire
    ... :picard: some life lessons cost more than others. :D
    Lousyweather, imacman and bogieb like this.
  18. Pete Zahria
    Pete Zahria
    New Hampster
    I will call and tell him that.
    :D
    Dan
  19. bogieb
    Glad it got figured out, and that it was an easy fix.
    ttdberg, CleanFire and imacman like this.
