Pallet buildings
Discussion in 'The Wood Pile' started by sirbuildalot, Nov 10, 2020.
  1. buZZsaw BRAD
    w
    Wasnt bad for me. I was kneeling on the other side of the peak of an 8 pitch. Putting a big shed dormer off the back. Yeah that would suck with 2x12's that long. Ive worked with 20' 2x10 and 2x12 PT but this was the longest. Never did much framing.
  2. sirbuildalot
    sirbuildalot
    Mass
    The Doug Fir was considerably heavier than the #2 SPF. Usually stuff over about 24’ was Doug Fir. Even feels denser when you pick it up. Under the span tables in the Building Code you can go further distances with the stronger DF.
  3. MFMc.
    MFMc.
    Idaho
    It seems that I’m also always looking for pallet wood ideas too. Here are a couple of red maple/oak standing butcher blocks. 7FC445FB-5F17-4267-B25B-C1D7C8B3466E.jpeg 34F8405C-ECEB-4C87-99E8-E03F50250C71.jpeg
  4. MFMc.
    MFMc.
    Idaho
    I have added a maple stool pallet wood a project over at Hobbies and interests.I’m afraid I may have hijacked this thread.
    T.Jeff Veal and Chazsbetterhalf like this.
  5. sirbuildalot
    sirbuildalot
    Mass
    I was able to get some more done today. I put up the top side pallets past where I knew the rafter would be. Then I traced the bottom of the rafter onto the pallets and added an inch and a half for the plate. Then I cut the pallets, nailed on the plate, and placed the end 2 rafters. I added a small piece of 2x stock and nailed on another 2x that hung lower, giving me an inch and a half space. This will give the rakes a finished look, and will give me somewhere to tuck the eventual 1/2" sheathing and Tyvek into.
    Next a strung the front and back walls and added some braces once straight. The front was bowed about a quarter inch in the middle. The back was bowed a quarter inch as well. Once I knew they were straight, I snapped a chalk line on the rafter tails and cut them so they were all the exact same.
    I kept the side piece up and inch and a half so it'd be flush with the top of the purlins.
    Working by yourself can be challenging with long lumber. Sometimes you have to get creative. I made a quick jig to hold the other end of the facia board. This 22.5' -2x10 facia was a heavy.
  6. sirbuildalot
    sirbuildalot
    Mass
    I then did the top facia. Same procedure. This time I used two "helper" boards.
    I nailed on a cleat under the top 2x6 plate to give it more strength.
    Everything is starting to shape up nicely.
  7. sirbuildalot
    sirbuildalot
    Mass
    Some of the rafters are bowed in the middles. Once I install the purlins, I will pull them straight prior to nailing.
    Done for the day. Time to put tools away. Kioti was a big help today with the 8' box. Daughter wanted to do inside stuff.
    I need to locate some rubber washer roofing screws. Should be able to put the purlins and metal up in one more good day.
  8. T.Jeff Veal
    Have you gotten your metal panels yet?
    Awesome job. Looks really good.
    I'd be honored to work with you on a project if we were closer, I see I could learn quite a bit.
  9. Woodwidow
    Really looking nice. it is quite a challenge doing all that by yourself.
  10. billb3
    Sure looks like a more better use of the concrete slab.
  11. sirbuildalot
    sirbuildalot
    Mass
    Yes sir. I have enough of the 2x4 panels I got from Rhode Island to do the roof. I just need some washered screws. I was lucky to have a father that taught me a lot and we got to work together for 20 years prior to closing the business in 2014. He also made me work hard from an early age and instilled some great work ethic.
  12. sirbuildalot
    sirbuildalot
    Mass
    I do plan to install some OSB I got and tyvek on the wall where the new building connects to the old shed. Once I install the sheathing I can then step flash the old shingles and then install the tyvek over the step flashing and tape the seam. Should provide much more water resistance.
  13. buZZsaw BRAD
    I work by myself all the time and have to get creative as well. Nice little rig/jig. Hows your hernia feeling after that fascia? Surprised you didnt use one by or is that all you had on hand?
    Chazsbetterhalf and T.Jeff Veal like this.
  14. sirbuildalot
    sirbuildalot
    Mass
    We always used 2x facias. I had enough to do the perimeter and they’re 30” OC.
    T.Jeff Veal and buZZsaw BRAD like this.
  15. buZZsaw BRAD
    Forgot, most houses the trim gets wrapped these days. Im dating myself. Are you wrapping the trim or stain/paint?
    T.Jeff Veal and brenndatomu like this.
  16. Canadian border VT
    His screen name is sir build a lot... he better have a metal brake and coil or come borrow mine!!:handshake:
  17. sirbuildalot
    sirbuildalot
    Mass
    The rakes and facias will be wrapped in aluminum. Most likely dark brown like I did on the woodshed trim. Yes I have a 10.5’ brake :thumbs:
  18. buZZsaw BRAD
    Brake is a great tool to have. Never have owned one as its something i dont use that often and no where to store it.
  19. SilentHatch
    SilentHatch
    ME, USA
    Glad to see the panda bear doing a visual inspection of the bottom of the 8' box on kioti.. :rofl: :lol:
    Wonderful progress, and always excited to see more!! Great work!
    Thor and T.Jeff Veal like this.
  20. Gpsfool
    Gpsfool
    U.S.A.
    Nice work! It looks fantastic. I’m lookin forward to see the final product.
