Wet basement work this Wednesday
Discussion in 'Everything Else (off topic)' started by yooperdave, Nov 23, 2020.
  1. yooperdave
    IMG_20201125_102643843.jpg IMG_20201125_112634119.jpg IMG_20201125_112644897.jpg IMG_20201125_112738690.jpg IMG_20201125_123533525.jpg
    After jackhammering a trench and cleanup/haul out of that mess, the floor was water sprayed and squeegeed into the trench.
    You can see in one pic where they drill holes into the base of the block allowing the trapped water to drain. (pics #2 and #3 show mud forming due to this draining water that was trapped).
    The trench is then flattened out and watergaurd/fill rock is added to keep watergaurd at desired level.
  2. yooperdave
    IMG_20201125_123545977.jpg IMG_20201125_123551991.jpg IMG_20201125_124822443.jpg IMG_20201125_132408759.jpg
    More rock is added to top of watergaurd and the all covered with a plastic type sheet. I believe that this sheet prevents the concrete from "seeping" down through the rock and into the watergaurd.
    You can also see the space between the watergaurd and the block wall. It is designed this way to allow to capture any moisture that may form on the exposed block wall a place to drain away.
  3. yooperdave
    IMG_20201125_132423206.jpg IMG_20201125_132547833.jpg IMG_20201125_133638055.jpg IMG_20201125_133905703.jpg
    The door leading to outside is not longer used, but a open grate trench drain was installed in front of it. The door leads up a set of poorly poured concrete stairs underneath a deck. :picard:
    Concrete is starting to be laid in and finished.
  4. yooperdave
    IMG_20201125_143647325.jpg IMG_20201125_143653205.jpg IMG_20201125_143716021.jpg IMG_20201125_143738621.jpg
    Pic #1 shows open trench drain in front of door. Probably a winter project..... make a new door? ;)
    There are two access ports in the water gaurd. These can be used for cleaning/flushing the system or even de-humidifier discharge hose drain access. But....... like I told the salesman, if it works right, I won't need a de-humidifier...right? :smoke:
  5. yooperdave
    As good and careful as they were in their work and clean up, it would never meet 99 lbs standards! She (we) spent the next few hours cleaning.
    Immediate plans are to re-paint the walls and then floors before the shelving and sauna wall is pieced back together. Hopefully, by Christmas, all will be back as it was!
    I want to give the concrete at least a week to firm up before I start putting sill plates for walls and legs for shelving onto it.
  6. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I'm looking into having this done in our house but reluctant to do so. 1840 stone house. No footers. Water seeps in from the back wall occasionally which is buried. I'm thinking that a spring runs in the bank. Might need to get a structural engineer in to advise.
  7. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    It looks like a nice installation! I hope you have a dry basement from now on.
  8. brenndatomu
    Wow, yooperdave with the photo documentation! :thumbs::faint:
    Looks good...it appears that the concrete they put in is real thin?
  9. yooperdave
    Thanks! Eric VW taught me all I needed to know..... :ithappened::ithappened::ithappened::ithappened::ithappened::rofl: :lol::rofl: :lol::rofl: :lol:
    I think the thinnest concrete is just under 2"....like maybe 1 1/2" ish
  10. yooperdave
    Concrete is drying nicely.
    Today, we started painting the block wall after disinfecting it with bleach/water solution. This will remove any growth that occurred due to the wet walls in the past.
    This bleach/water and scrubbing routine was done annually by order of 99 bs.
  11. blujacket
    blujacket
    Kettering, OH
    Tell me that's not Parris Island. Women di's for men now? WTF
  12. Eric VW
    It is almost 2021....
  13. yooperdave
    Compared to men pretending to be women, that's nothing!!!!
    Chazsbetterhalf, Ron T, mat60 and 2 others like this.
  14. billb3
    Chazsbetterhalf, mat60 and yooperdave like this.
  15. yooperdave
    Floor and wall painting are moving along a lot faster than I had anticipated. 99 is helping out a lot as she wants her organized basement back together.
    Today, I hope to get the wooden sauna wall put back together as it had to be removed for the watergaurd install. Also, some shelving will be re-installed and most probably a 4' fluorescent light installed over those shelves. There was only a screw in ceiling light fixture there before and as everyone who is a bit older knows.... the older you get, the more light you need! ( The light in that area will be needed probably no more than once a week (max). That is why I won't use an LED fixture there.)
    Chazsbetterhalf and mat60 like this.
  16. blujacket
    blujacket
    Kettering, OH
    I went to boot in 1988, 3rd Battalion. I don't care what year it is. That's just wrong to me. This country gone to hell
  17. yooperdave
    That ain't all they're letting in the military.......... :(
  18. Eric VW
    Believe me sir, I understand your position. :salute:
    Forgive my mentioning of the year, it was meant as an observational jest at the larger thing that is our country. :confused:
  19. yooperdave
    Got the sauna wall put back together and then installed the benches and wall trim. Sauna is done.
    Re-assembled the shelves and then painted them. Everything...legs, supports and shelving. May need another coat of paint but don't think it'll get one. 99 is chomping at the bit to get the basement put back together.
    On a side note, I talked to the install company of this project and let them know that there is still a little dribble of water finding its way to the floor drain. They called me this morning and scheduled another 15' additional install of watergaurd to eliminate that flow.
    No cost as it is covered under their warranty. :handshake:
    So, there'll be some more pics in a couple weeks! :ithappened:
  20. Erik B
    Erik B
    Western Wisconsin
    Sounds like there will be a sauna party soon at yooperdave place:hair::hair::thumbs::thumbs::rofl: :lol::rofl: :lol:
