What's on the grill or smoker?
Discussion in 'The Smokehouse' started by Genius, Jun 20, 2016.
  1. Chvymn99
    Just saw this... Will get it this weekend copied for you.... :handshake:
  2. Chvymn99
  3. Chvymn99
    Meat Loaf Recipe...
    2lbs of Hamburger
    1 egg
    1 8oz tomato Sauce (use 1/2 now and the other 1/2 later)
    Medium Onion (diced up)
    a Little Ketchup (I did about 1/4 cup)
    1.5 cups of Corn Flakes (then partially crush them) (use enough to firm up the hamburger)
    Mix Together in mixing bowl ( I do by hand)
    In a pan divide meat loaf in halves
    Bottom - work it like a big hamburger patty. Flatten out enough that you can kinda of make a slight
    depression in the center of it...
    Load it up with enough shredded cheese of your liking
    Then put the rest of the hamburger on top (I did it in 1/3 strips... Then tie them and the bottom together
    by kinda of working them together, delicate step so that the cheese stays in side)
    Then Put the other half of the Tomato sauce on top
    Squeeze a little tomato sauce on top
    Fill bottom of pan with 1/2 cup of water
    I cooked mine on 225F for 5 hours to 160F internal temp...
    (basod )
  4. Chvymn99
    Two Sword Fish Steaks...
    Sean, Knothead, Marvin and 8 others like this.
  5. Chvymn99
    Put a Salmon Fillet on...
    6AE0A665-4D73-4E43-AF40-3F5BBADD221E.jpeg 72CCCD0C-F1A6-42E8-89DE-E4F0FAEED436.jpeg
    Sean, Knothead, Marvin and 10 others like this.
  6. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Just got into the smoking game! Can’t believe I waited this long. Did some legs and thighs on my Green mountain grill today. Turned out great!
    Sean, Knothead, Marvin and 9 others like this.
  7. T.Jeff Veal
    Found some thicker Angus ribeyes at Walmart Saturday. Gave them a try. First time I've cooked steak on the pellet grill/smoker. Used mesquite pellets. I cooked them a little to long, but they were still tender. 1010201900.jpg 1010201928.jpg
    fuelrod, Knothead, Marvin and 9 others like this.
  8. eatonpcat
    They look delicious Jeff!!
  9. T.Jeff Veal
    Thanks, they were well done, but still good. Only ate half Saturday, take the other half to work tomorrow
  10. T.Jeff Veal
    1016201715a.jpg Trying out some Brandon Scott crappie filets with blackened seasoning. Smoking with mesquite pellets
  11. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    Let me know when you run out. Only caught 600 this month...
  12. T.Jeff Veal
    That was the last of them...:(:(
    These sure were :drool::drool: cooked on the smoker.
  13. Chvymn99
  14. Chvymn99
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  16. eatonpcat
    Dang, Skeet and Kev...Looks like dinner was good!! :drool::drool:
  17. Chvymn99
    means plenty of leftovers for the work week...:thumbs:
  18. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  19. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  20. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
