Can I tuna Jotul on my patio?
Discussion in 'The Wood Pile' started by mrfancyplants, Sep 28, 2020.
  1. jrider
    jrider
  2. Semipro
    Semipro
    SW Virginia
    Don't be surprised if you need to add a stack to it to get it to burn well.
    I tried to do break-in fires and leak tests on a new Jotul Firelight outside once and was amazed at how badly it operated without a stack.
    The flue is the thermal engine that powers the stove.
  3. mrfancyplants
    mrfancyplants
    South Carolina
    I have a piece of galvanized? tube that I scavenged a discarded piece from an hvac. Hopefully it fits without too much effort. Also not sure how long it will last, but should give the stove some breathing room.
    brenndatomu and Midwinter like this.
  4. Semipro
    Semipro
    SW Virginia
    A galvanized pipe heated hot enough will put off zinc oxide which is not good to breathe.
    I realize though that this is an outside install.
    Just something to consider.
  5. mrfancyplants
    mrfancyplants
    South Carolina
    Good point, I’ll double check if it is galvanized or not.. maybe it is worth getting a rain cover of some sort too.
  6. moresnow
    moresnow
    Black snap together wood stove connector pipe from most any BB store, farm fleet, or hardware store. Super cheap.
  7. Midwinter
    brenndatomu likes this.
  8. Midwinter
  9. Eric Wanderweg
    What a strange place we all find ourselves in. Symmetry everywhere.
    brenndatomu, Midwinter and Semipro like this.
  10. mrfancyplants
    mrfancyplants
    South Carolina
    Yeah, I think the one I have is galvanized based on that marbled look
  11. buZZsaw BRAD
    yup, thats galvanized.
  12. mrfancyplants
    mrfancyplants
    South Carolina
    I had to fire it up without a pipe.. it took a little while to get it going, but working well now.
    Does anyone know if the Jotul 3 is supposed to have a top baffle?
    home brewed beer using kveik yeast (Norwegian) and Jotul stove (Norwegian). I should go get some of the Norwegian maple.. it should be about dry by now.
  13. buZZsaw BRAD
    Looks inviting. I can feel the heat :coldfire:from here...must be black locust in there! :whistle:
  14. mrfancyplants
    mrfancyplants
    South Carolina
    Close, as the wood pile is stacked... it is tulip poplar!
  15. Skier76
    Skier76
    CT and SoVT
    Our neighbor a few houses up from us in VT does that. It's in his front yard with about 6-8' of single wall still attached. He was burning it last night. I think he partially tarps it when not in use. It's been outside for a few years now. It's a bit off the road, so I can't see it all that well. I'll try and see if it's a cast stove or a steel unit.
    brenndatomu, Midwinter and Cash Larue like this.
  16. mrfancyplants
    mrfancyplants
    South Carolina
    I think no top baffle for the model.
    I went to HD looking for the pipe, with no luck. I can have it shipped to the store though. Am I going to need to support a 48” pipe with something? Maybe a couple ties to the front corners of the stove and one to the back?
  17. mrfancyplants
    mrfancyplants
    South Carolina
    Hmm, I wonder if I should switch for the top pipe instead of out the back.
  18. Warner
    Top exit and a rain cap on the pipe is what I would do.
    brenndatomu and mrfancyplants like this.
  19. mrfancyplants
    mrfancyplants
    South Carolina
    The wife just weighed in to “leave it the way it is “ for the pipe direction :( Rain cap like this($30)? Or is there a simpler version:
  20. Warner
    There is a simpler version I’ll try to find a pic.
