Changing from .325 to 3/8LP on Ms 250?
Discussion in 'Chainsaws and Power Equipment' started by JW IN VA, Oct 11, 2020.
  1. JW IN VA
    JW IN VA
    Virginia mountains
    I read somewhere an opinion that the switch would wake up an 250.
    Has anyone tried it?
    Been thinking of trying it but am stocked up,well overstocked,on chains for the .325 setup I have.
    I like the saw as is but,if it would help,I might want to try it.
  2. farmer steve
    farmer steve
    top of the hill york co. PA.
    JW that's all I've run on my 250. James Miller said his 250 was a dog. I gave him an old bar and chain to put on his and he was happy. 16 " bar. Just buy a 261 to run your .325 chain on. :whistle:
  3. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Pretty sure that would make your 250 slower. All I run in my 50cc saws is .325 m big saws run 3/8. My FIL’s 250 runs .325 and cuts right with my 026/260.
  4. chainsawsoldier
    chainsawsoldier
    NE Kansas
    I put a 3/8 picco onto a MS290. I changed out the sprocket for a rim sprocket, so you only have to pull an E clip to change the chain pitch.
  5. JW IN VA
    JW IN VA
    Virginia mountains
    I'm sure it would if I used full size 3/8 pitch.My son switched his 290 from .325 to 3/8 ut didn't keep it there long.
    I was referring to the 3/8 pitch Low Profile.Smaller tooth on it you file with a 5/32" file.
  6. JW IN VA
    JW IN VA
    Virginia mountains
    I've got an 026 I'm going to rebuild which could use up the chain if I get an 18" bar for it.Might be link or so off but plenty of adjustment on the bars.
  7. farmer steve
    farmer steve
    What DL count is your .325 chain?
    T.Jeff Veal and amateur cutter like this.
  8. JW IN VA
    JW IN VA
    Virginia mountains
    68 for the 250
    74 for an 026
    Both 18" bars
    I think an 026 with 16" bar calls for a 67 link.
  9. sirbuildalot
    sirbuildalot
    Mass
    My 250 runs .325. My Dolly 5100 runs 3/8”. I don’t envision 3/8” making a 250 cut any quicker. You’d be making a wider kerf
  10. amateur cutter
    My guess is the 250 would do pretty well with the 3/8 LP chain. A fair amount of people seem to be going that way with good success on smaller saws. I run it on an 011AVT & 020 AV & really like it. Everything else runs 3.8 .050 RS or RM, but I run pretty big CC's on shorter bars. I buck with 75cc or bigger usually.
  11. bang
    bang
    South central Indiana
    I put a 3/8 Pico on a 250 and like it, I don't remember the sprocket size though. I only use it for limbing and it does a good job.
    T.Jeff Veal and SAWMIKAZE like this.
  12. SAWMIKAZE
    SAWMIKAZE
    PGH
    Here's what you want.
    And I'll tell you why, it's a mini spline drum. So if you decide you don't like the picco on your 250 you can swap to a .325 rim and continue as you were.
    No brainer to me.
  13. Dumf
    Dumf Banned
    Butt--it's not only the .325 or 3/8.
    Be sure the chain is NON safety ( Stihl yellow ).
    farmer steve likes this.
