170 a FLOP!
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Sep 27, 2020.
  1. buZZsaw BRAD
    It is and will go to the dealer when i PU two other saws they are fixing.
  2. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have a one year old 170 I use for carving. I know it isn’t safe, but if it doesn’t start with the choke lever in the run position. I full throttle start it. Your a big guy, so you can manage this safely. Not ideal, but it works. Good luck.
  3. Dumf
    Dumf Banned
    Brad....DEALER.
  4. buZZsaw BRAD
    Good to hear from you Woodsnwoods! Your absence has been noticed. Hope all is well.
  5. Mag Craft
    That sounds like the symptom for a bad crank seal. You go sideways and the seal starts sucking in air and when put up right it stops.
    M2theB, Midwinter, mat60 and 6 others like this.
  6. In the Pines
    In the Pines
    that is a good point, never thought about that.
    M2theB, Midwinter, Mag Craft and 4 others like this.
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I got my wood done very early this year and tried to avoid electronics. Tried some new wood hobbies though. 4E04FDE0-A6DA-4ADA-B3AA-9582A1B01DEE.jpeg 6AC9188E-AD07-4C4D-984B-92C2BEBCD445.jpeg AA4BB029-0437-4AA0-8581-73621423E93F.jpeg 1564750E-3496-4A7A-81D3-AB7A9AD322FF.jpeg
  8. buZZsaw BRAD
  9. T.Jeff Veal
  10. NortheastAl
    NortheastAl
    Putnam County NY
    Looks like Birdseye maple. Great job Woodsnwoods has done.
  11. buZZsaw BRAD
    Gave the 170 another chance today. Had some smaller cherry rounds to buck. Burped fine on full choke and started at half. Set her down to idle for a minute, wouldnt get to full chain speed bucking. Stalled a couple times immediately after i finished a cut. After bucking a few logs, i got frustrated :hair:and the 194t finished them off.
  12. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I think it's time for the saw to hit the hiway. Life is too short to deal with a poor running saw.
  13. buZZsaw BRAD
    I agree even if its under warranty and dealer will get to right it. 193 or 194 rear handle in my future. Im tired of being aggravated when wanting to cut wood.
  14. OldJack
    OldJack
    Saskatchewan, Canada
    Your gas tank may not be venting. Try opening the gas cap for a breather between cuts. In any case it's Stihl's problem if it's still on warranty. An MS170 is nothing for warranty compared to a $half $million John Deere combine. One of the things they do on the pre-delivery check is to back her up to a bush, open up all the hatches, wind her up to full throttle and dodge all the nuts and bolts that fly out.
  15. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Sure, as long as the saw is described as having issues before “sending it down the road.”
  16. buZZsaw BRAD
    I told dealer about it the other day and said to bring it in. Once its running fine then CL here it comes.
  17. Dumf
    Dumf Banned
    No CL for the 170 Brad (errrr .... Corleone)
    For most of us it's a "pick up" saw when the usual ones get hung up, bound, or just out of it in normal use.
    It is ideal for limbing in severe blowdowns to clear up for the big boys.
    Stihl made it as a "woman's" saw ( excuse the chauvin please ) : light, simple, really reliable ( most of the time).
    Your dealer has to do the fix. Be your own advocate.
  18. Hedgerow
    Hedgerow
    SW Missouri
  19. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Then buy a Husqvarna
    I’ve been resisting the urge to jab at you since this thread started, but I just couldn’t take it anymore :rofl: :lol:
  20. Dumf
    Dumf Banned
    Whiskey Tango-----what's "AHUSKAVARNA" ? :faint::faint:
    Sounds like one of those contortions in the Kama Sutra. :zip::zip:
