You can keep em
Discussion in 'The Wood Pile' started by jrider, Jul 21, 2020.
  1. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    Here’s my saga on big chunks. I work alone, am 56, and have learned about it by doing and reading here.
    I got 2 20 foot trailer loads of 4’ oak 36” given to me with my Timberwolf twp1 purchase two years ago.
    I worked my butt off cutting them down and still have 3-4 pieces still out there pushed into the fence line where I can’t see them.
    First was trying to wedge smaller with maul and wedge.
    Then I used my tractor grapple to set them on the splitter and nibbled them from the side. Ever try to wrestle Both chunks at once ?
    Then I used my pallet fork extensions on the bucket to set the piece on the splitter and leaving the forks there for the first split or two. The forks helped me keep them from falling out of control. This actually worked pretty decent. Then throwing the splits into the bucket conveniently there at the end of the splitter.
    Then I bought a 3 point splitter that went vertical. That thing went up for sale within the first week. Big PITA.
    Let’s see...
    I made a log lifter from a cherry picker welded to back of splitter. That contraption tried to turn the splitter over.
    I read on here about “noodling”. Ok. I’ll try that. With trusty MS250 in hand I attempted to cut one from the face like you hit it with a maul. Nope. (Afterwards reading on here and asking questions, you guys told me about cutting it lengthwise rather than crosswise.
    I feel guilty about them 3 or 4 big pieces of oak laying in the tall grass. I might someday try noodling one the right way and see. But that grass hides them pretty good for now.
    I have about 5 cord ready in a Holzhaus and some totes. And a large pile of stuff from cutting down three big butternuts in the spring to process up first.
  2. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Says my biggest piece is around 799lbs! No wonder I broke out in a small sweat moving it. May check the other ones later on. Thanks for the calculator, saved it in my favorites.
  3. sirbuildalot
    sirbuildalot
    Mass
    While the MS250 is a great homeowner saw, a noodler it is not. I have one, and its just not big enough or powerful enough to noodle that size of a round very efficiently.
    To noodle, you have to go with the grain, which also means the bar has to be as long as your firewood is processed to plus a couple inches that you loose with the cover and dogs.
    The other thing to consider is to wedge them from the edges and take smaller bites. Everyone tends to put the wedge in the dead center of a round. While this may work in some cases, more often than not it wont pop the round apart.
  4. jrider
    jrider
    Busted my butt getting these into half moon pieces small enough the log lift can handle. Ran two tanks of gas through the saw cutting 17 pieces and noodling them far enough down that I could bust in half with a maul. I took off my dri fit shirt and wrung it out twice...don’t think that’s supposed to happen lol. Now eating a popsicle before cutting some normal size wood! Oh, and my shorts looks like I peed myself. Haha
  5. sirbuildalot
    sirbuildalot
    Mass
    I think using forks is the best solution you listed for your situation. Id build a platform to put the halves or quarters on (if they wont fit in your bucket). I've done it this way before.
    eatonpcat, Hinerman, Chaz and 5 others like this.
  6. Rich L
    Rich L
    Eastern Mass.
    Chaz, Chazsbetterhalf, dahmer and 2 others like this.
  7. T.Jeff Veal
    I hear ya, jrider I wish I was closer. But you know we can handle them.
    Guess we are blessed to have the equipment to do it. As TurboDiesel said, we use the 25 ton splitter to break them down, metal grate makes sliding them much easier. 0326201012.jpg Then put the pieces on the ramps to the fast cycle splitter to finish. 0328201902.jpg Thanks to the calculator, this 38"×32×6' log weighs about 2560#. 0717201213b.jpg
    I broke down 6 rounds that size last night 0721202127_HDR.jpg Some of the biggest we have ever had...
    These last 3 pics are 1 load/ 1 spar take down, tractor would only handle 20" long round. 8 rounds on the trailer, almost 8k. Avg weight was 975 # each. Glad that was yrs ago when Ibwas a young man...lol. FB_IMG_1549203245638.jpg FB_IMG_1549200590540.jpg FB_IMG_1549200659192.jpg
  8. dahmer
    dahmer
    Ellwood City PA
    https://sherrilltree.com/content/legacypdf/Log_WeightChart.pdf
    Screwloose, Chaz, Stephiedoll and 3 others like this.
  9. dahmer
    dahmer
    Ellwood City PA
    Love them. Been there 8 years now, no problems. Only problem is I can’t find more.
  10. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Midwinter, jrider, Screwloose and 4 others like this.
  11. Rich L
    Rich L
    Eastern Mass.
    I scored some from craig's list.Not enough though still looking.
    Midwinter, Chaz, dahmer and 3 others like this.
  12. dahmer
    dahmer
    Ellwood City PA
    I bought 40 at $5 each from a local reclaimed pallet dealer, he hasn’t got the heavy duty ones in since. Another guy guy bought 50 after I was there, no more since.
  13. Hinerman
    Hinerman
    NE Oklahoma
    How long are your rounds? No way those should exceed 500 pounds unless you are cutting 20-24" lengths.
    T.Jeff Veal and Screwloose like this.
  14. jrider
    jrider
    16”
    Chaz and T.Jeff Veal like this.
  15. jrider
    jrider
    Go to my thread “guess the weight game” from back in April. This 16” long 27” diameter red oak weighed 389 pounds
    Biddleman, Chaz, Hinerman and 2 others like this.
  16. MAF143
    MAF143
    North Central OH
    Noodling lengthwise instead of "down" the log makes a HUGE difference in the time and effort it takes to noodle. Give it a try, it will work fine with the MS250. Slow and steady will still get it done.
    I don't noodle unless I have to, but I get into some big stuff occasionally. Normally I noodle with my 25" bar on either the 391 or the 362, but I have noodled 32" Pin Oak rounds with my MS250 just to see how it goes. I have an 18" bar on it and I cut rounds at 22" so I have to hit 'em from both ends. I always keep my chains sharp and although it is slower going, I was able to noodle some of that Pin Oak just fine with the 250. It clogs up with noodles quicker than the larger saws, but that's kinda to be expected with the smaller butt on the 250. Bigger saws are nice, but I'm a big believer in "run what you brung". MS250 is both an inexpensive and impressive saw with an excellent power to price ratio. They respond very well to a muffler mod also. I don't care what powerhead you have, the sharp chain is the winning ticket. $20 on a box of files is way cheaper than big saw that is only needed once in a blue moon. Speaking of blue moon, I'm thirsty... I better go grab a PBR... LOL
    I usually only noodle 2/3 of the way through then pop them the reset of the way with a wedge to save time.
    Nuthin' against big saws... I love em, just can't justify buying one for my needs.
    Proper orientation of the saw to noodle. I never timed one to see for sure but I would guess 3 to 5 times faster than cutting across like on an Alaska mill. This is the 391.
    This is the 250 and it noodled a few of these rounds cuz I ran out of gas in the 391, This saw orientation is the "hard way". It's just sitting in there for the picture.
  17. Hinerman
    Hinerman
    NE Oklahoma
    WOW!!! No problem for the TW6
    Midwinter, metalcuttr, Chaz and 3 others like this.
  18. jrider
    jrider
    Under 30” no, go over that and now I get concerned
  19. Hinerman
    Hinerman
    NE Oklahoma
    I understand. I have lifted bigger and broke mine; but mine is not a TW either. When I had it fixed, the welding shop said it would mostly likely break again until I beefed up the construction. I will have a complete new lift built next time it breaks. I lift some heavy rounds with it (36" range of oak)---heavier than I thought according to your info. And it gets abused as a table; my helpers dropping rounds on it can't help.
  20. jrider
    jrider
    Yeah when those big boys finally break apart they can be a real b*tch to try and catch. That’s why even though I don’t like to, I will noodle them in half once just so as not to bust up my equipment or worse yet my helpers
