First time for me
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by The Wood Wolverine, Jun 29, 2020.
  1. The Wood Wolverine
    So after what, 11 years of wood burning, this happened last week.
    We heard a bird feeding it’s young in that direction and sure enough a starling flew out. So I, like a dummy, throw a couple noodles in the stove hoping to smoke them out. No bueno. So I go up and have a look. damm it! Cutting that big ugly maple down across the street made them migrate to my stack!
    So I removed the top section to clean it out. The smoke did get to the young. I don’t feel any remorse for starlings. Nasty nest robbers they are. Pulled out the material and it had to be at least 10” of packed tight stick/straw/stuff!! Nesting went up to my hand in the second pic. Unreal.
    So now I might need to find something to prevent this from happening again. Any ideas? I’d rather not go up twice a year to cover and uncover.
    farmer steve, M2theB, Chaz and 5 others like this.
  2. chris
    Much as I hate the stuff, a length of 3/4" sq mesh around the top prevents the intrusion - course it does load up and needs to be cleaned if not removed at start of burn season.
    Chaz, RGrant, Chazsbetterhalf and 6 others like this.
  3. Eric VW
    Large mesh screen?
    Do clean from the bottom up?
  4. chris
    got to be small enough mesh they can't get through. yes i clean from bottom up . I do not have a mesh on mine at the current location. Previous location I would remove at start of burn season - replace in spring- but that was a low ranch roof. Current place is very steep floor of attic to peak inside is at least 15 ft. total flue length is just shy of 30ft, stove is on main floor.
  5. Eric VW
    Right. Of course. :yes:
  6. The Wood Wolverine
    I was concerned about whatever I use loading up w creosote. I clean from top down with rods typically.
  7. Eric VW
    Hmmmm.... do you have elbows in the flue path? Or is your stove in the finished part of y’all’s house- sorry, can’t remember.
  8. brenndatomu
    This...or I'm not so sure its even called screen...perforated metal I think, in stainless.
    My caps have holes big enough that some birds could get through, but they don't seem to mess with it...and its not so restricted that it gathers buildup causing draft issues. I've had that in the past though, 1/2" holes I think it was...too small for sure!
    Mine looks kinda like this...only the holes are more square.
  9. The Wood Wolverine
    2 90’s at about ground level, stove is in basement. Then 2 slight elbows high up to get around the roof edge.
  10. The Wood Wolverine
    Thanks! Gives me some direction to look towards.
  11. Eric VW
    I remember your basement pics now.
    No way you could run the brush up from the bottom, so there goes my thought.
  12. The Wood Wolverine
    I have a very small space under the T outside to catch soot. I could drop a rope down and pull up for cleaning but no way to push something that way.
  13. savemoney
    Could starting a smoke fire every week during nesting season take care of the issue? I'm no fan of anything that has you up on the roof too often. I'll hire it done before taking avoidable risks. Those who get up on roofs and chimneys professionally are usually safe at what they are doing.
  14. The Wood Wolverine
    My roof isn’t very steep at all but I really don’t like walking on the shingles. Not sure but I’d venture to say they could plug it up in less than 5 days. I’m right beside fields that get used for stray and hay so the materials are very plentiful and close.
  15. Eric VW
    I use a mirror in my cleanout to look up the chimney during the daytime.
    Too bad you didn’t a have a set of really flexible of rods that could make that outside (chimney cleanout) bend, with an air line zip tied to it... an in-line air gun down at the bottom cleanout- couple of blasts- done.
    Edited to add- you could use some pex pipe to do this all-in-one... a couple of adapter fittings to an air gun and you’re golden.
  16. Eric VW
    A long remnant of loop pile carpet, rolling it out before (carpet face down) you does a lot to protect shingles, and really grips the asphalt shingle surface.
  17. The Wood Wolverine
    I like where this is heading...
  18. Eric VW
    Of course, you’d want to not involve the use of a cap screen. :D
  19. The Wood Wolverine
    So tell me, how do I invite starlings to nest in my flue!? Lol! :rofl: :lol:
    Chaz, savemoney, Eric VW and 3 others like this.
  20. DaveGunter
    DaveGunter
    Mm mm smoked baby starling! Apple wood?
