firepit ideas...
Discussion in 'The Smokehouse' started by splitoak, Jul 3, 2014.
  1. splitoak
    splitoak
    jefferson co wv
    Hey guys i wanna make a firepit in the yard...i would likes some ideas on where to start..pics please..i like the keyhole design...also maybe a round one also for cooking on a tripod....thanks ahead..:popcorn::campfire::drunk:
  2. Stinny
    I have always liked just rocking up a big ring. This is about 4' across inside the rocks.
  3. papadave
    Mine is similar to Stinny's, but 6' ID.
    Smaller rocks.
    Would be fairly easy to add a section for cooking with a rack.
    Nothing special. The PO had this one, but it was smaller. I just dug down a little deeper, after putting the rocks/stones where I wanted. I filled a couple low areas with the stuff I dug out.
    Every couple years, I dig out the ashes.
  4. Grizzly Adam
    Grizzly Adam Guest
    I cooked on a tripod recently and wow, I really liked it! That I conjunction with the above ground pit pictured above would be pretty sweet.
  5. Stinny
    Have seen a couple HD swing arm set-ups that are cool... arm swings a pot or grill out over the fire, then back beside a small tray table. I'd rig that up if I did a lot of grilling over a firepit for sure.
  6. splitoak
    splitoak
    jefferson co wv
    I saw the pic grizz..pretty sweet....what type of pot was it...like a large dutch oven with a hanger?....also you think pavers from home depot would stand the heat?
    blacksmith and Well Seasoned like this.
  7. Grizzly Adam
    Grizzly Adam Guest
    It was a 8 or 10" Dutch oven. If the pavers are real stone, maybe? I would just get field rocks.
  8. Midwinter
  9. mark.nowak
    mark.nowak
    Sycamore, IL
    Here is the one I built in a previous backyard, when I was living the subdivision life.
  10. Well Seasoned
    Those are so cool Midwinter! :thumbs:
    Here is my pit.....
  11. Stinny
    NortheastAl and Well Seasoned like this.
  12. Well Seasoned
    Thanks- will report back after the thaw. I mighta hit it with the plow.
    NortheastAl, blacksmith and Stinny like this.
  13. Buttercup
    Buttercup
    Tennessee
    L-32 Multi-Level Campfire Ring Pilot rock is the manufacturer. I have personally used one of these camping and they are great. Every time we camp at this particular place we always cook over the fire.
  14. Matt Fine
    Matt Fine
    New York
    You plow the grass? :D
    Well Seasoned and NortheastAl like this.
  15. Stinny
    Hehehe... been there... hope you didn't do much damage to either... ;)
  16. Twelvevoltman
    Twelvevoltman
    N.E. Tenn
    Do you plan on cooking over it? If so, look up keyhole fire pits. This gives you the ability to control the heat underneath your cook utensils.
  17. bogydave
    Scotty has a great "keyhole" shaped one.
    Have a good fire & cook at the same time on the narrow end :yes:
  18. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Doesn't everyone? All my snow goes in front of the house on a 10' wide strip between the road and fence. Once that fills up I bring all the snow up the driveway, then up the side of the house, and push it to the back corner of the yard. Total PITA, but still easier than my snowblower.
    Well Seasoned and Midwinter like this.
  19. Midwinter
  20. Scotty Overkill
    I built our sunken keyhole pit many years ago, and it's been used very hard. It works wonderfully for both kettle and grill cooking. Here's a few pics....
