What'd i get Myself Into?
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Jun 7, 2020.
  1. buZZsaw BRAD
    My friends friend cuts wood for him. I do once in a while when i have time as well as give him some wood as well. Ive seen his other friend cut and its a scary thing. My friend asked if i could sharpen some chains for his friend. I obliged as he lets me store wood there. This is what i got:picard: IMG_2631.JPG IMG_2632.JPG
    A dozen chains that look like they've been used once. Some rusty, some very dull. I have some serious hand filing ahead. His friend is the type that cant be told anything either.
    I mean no disrespect, but not the sharpest tool in the shed.
  2. Chaz
    Chaz
    Southwestern NY
    Talk about rode hard and put away wet
    :doh:
  3. buZZsaw BRAD
    OH??? you mean the chains??? Thought you mightve been referring to something else!!!;)
  4. MikeInMa
    Time to get yourself a grinder. You can get accustomed to it on those chains, before yours.
  5. Camber
    Camber
    Montana
    looks like some safety chains in there too. Time to up the amount of wood you store at your friends place by 10 cord:rofl: :lol::hair:
  6. amateur cutter
    That's a nasty mess.Soak those rusty chains in a pan of auto trans fluid & they'll do a lot better. Throw away the "safety chains".
    Chaz, Chazsbetterhalf, Camber and 7 others like this.
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Shoulda not got in that spot in the first place!!
  8. brenndatomu
    Bingo...those guys need a good soak! I've used drain oil mixed with diesel or kerosene before too...let them soak then work them around a little, then soak some more...rinse and repeat as needed.
  9. thewoodlands
    thewoodlands
    I'm not sure a dealer would even mess with those rusted chains, if they did there would or should be an extra charge.
  10. T.Jeff Veal
    A mess...good luck
    Chaz, Chazsbetterhalf, Camber and 4 others like this.
  11. buZZsaw BRAD
    Ive been slowing trying to do that!
    Chaz, Chazsbetterhalf, Camber and 3 others like this.
  12. MAF143
    MAF143
    North Central OH
    I had a buddy bring his saw and a couple chains over once, he had asked if I would sharpen them for him. About halfway through the first chain, he said, "wow, is that all there is to it?" He wanted to try and he did a pretty good job and I showed him all the tricks I know (not too many, LOL) and he was off and running. He called me a couple days later and had gone and baught files and everything and was happy as could be that he learned something new.
    Any way you could have your friend have his freind meet you at his place and teach him the basics? Very wise old tale about teaching a man to fish???
  13. Canadian border VT
  14. buZZsaw BRAD
    Point well made, but ive met his friend a few times and he is the type that doesnt take well to be told what to do or taught anything so i leave it at that.
  15. MAF143
    MAF143
    North Central OH
    That's too bad, sorry to hear that.
  16. stuckinthemuck
    stuckinthemuck
    Good luck buZZsaw BRAD !! Wonder if WeldrDave ’s method of removing rust with a solution of washing soda and electrolysis would work.
  17. WeldrDave
    It will. :yes: Another thing that will help eat rust, "brake fluid"!
  18. Mag Craft
    The last time I sharpened that many chains for someone I got 75 dollars and a MS460 that had been dropped out of a tree and it messed up the spark plug hole on the cylinder. I used the money to rebuild the saw including another cylinder that I found used and the saw is still running great to this day.
    I did all the chains at the time on a grinder and I also had to lower some of the rakers. Time consuming job for sure so I do not take on jobs like that anymore.
  19. The Wood Wolverine
    Might not be very cost effective in the long run but when I get a loop or two like that, I put them in a plastic freezer bags with PB blaster. Then draw as much air out as I can with the vacuum sealer and not suck liquid which prevents the sealing. I let em sit like that for a week or so.
  20. Screwloose
    first a good degreasing then a soak acetic, "vinegar" or phosphoric acid.
