Hmmmmm
Discussion in 'OWB's and Gasification Boilers' started by Creekin, Apr 12, 2020.
  1. Creekin
    Creekin
    Manitoba
    I figured i would start a new thread about my issues with my g400
    I have been having leak issues for a good chunk of this season that started out minor but have gotten worse
    Last few days have had major issues of getting water temp up past 100° and discovered this when I checked this morning 20200412_110229.jpg
  2. Creekin
    Creekin
    Manitoba
    Opened the bottom chamber door and had a bit of a waterfall
    campinspecter and brenndatomu like this.
  3. Chaz
    Chaz
    Southwestern NY
    Not good at all.
    :hair:
    brenndatomu and Chazsbetterhalf like this.
  4. synermead
    synermead
    Okotoks
    I had a leak in mine as well. One of the welds that hold the side shields started to leak. (Last year) I cleaned it out and had a welder come patch it using the appropriate rod for SS. Has been fine ever since. Good thing there is lots of room inside the 400!
    campinspecter, brenndatomu and Chaz like this.
  5. synermead
    synermead
    Okotoks
    Still have ours running as well. Seems like Winter doesn’t want to surrender.
  6. synermead
    synermead
    Okotoks
    Do you have a tote to drain out the water. Will have to before you weld it. Just lower than the fault of course.
  7. Creekin
    Creekin
    Manitoba
    I have been in talks with heatmaster about getting a welder to come out, but that was before the world went nuts
    What I'm thinking is just trying to limp out the season, drain the unit, load it up on a trailer and bring it back to heatmaster so they can do it in house
    (Benefits of being 15min away)!
  8. Creekin
    Creekin
    Manitoba
    I climbed up on top of it last night and realized that most of the flues are full of mud, hoping to clean out this morning and hopefully it will allow enough airflow to get a higher temp
    Right now its struggling to heat the house with outside temps hovering around 0°
  9. synermead
    synermead
    Okotoks
    If your 15 minutes away I’m surprised they don’t just send a guy out. For the amount of work to unhook it, move it, fix it then all again in reverse. Would be cheaper to just get you own welder to come out. Seriously it’s not even an hour job. I’m in construction there are ways we do our work by keeping a safe distance and all is good. At least get heatmaster to supply the guy the proper welding rods.
  10. synermead
    synermead
    Okotoks
    Do you have a wood stove for back up? I wouldn’t run it if it’s leaking.your going to plug up everything and will take half a day to clean it out. Trust me on this one.
  11. Creekin
    Creekin
    Manitoba
    campinspecter and Highbeam like this.
  12. Creekin
    Creekin
    Manitoba
    I think I found why the temp was so slow to rise, my damper on the front was a bit stuck
    Now back to working good, just filling water in every few days
    I took the turbs out a number of weeks ago and washed out any mud that was clogging the flues (after a cool down)
    The other day
    campinspecter and synermead like this.
