A gifted husqvarna 350
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Mar 31, 2020.
  1. MikeInMa
    As long it gets my pinched saw out, it's fine. :headbang:
  2. TurboDiesel
    Gotta work to get new work buddies...:hair:
  3. bushpilot
    bushpilot
    Eastern Washington
    I'd run it with Seafoam in the gas, perhaps a little heavier mix than usual.
  4. Nixon
    Nixon
    West Sunbury,Pa .
    If you suspect that the carb is crudded up , pull the carb and rebuild it . It’s probably needing a bit of TLC given that the saw appears to have a decent amount of run time on it . At the very least , pull the pump side ,and check the filter screen . Bet it has a lot of wood fiber in it ...
  5. The Wood Wolverine
    I’d agree. Somewhat finicky to tune, could be a slight restriction in fuel due to this. :yes:
    MAF143, In the Pines, M2theB and 2 others like this.
  6. WeldrDave
    :rofl: :lol::rofl: :lol::rofl: :lol: Yeah, I had to ask! I looked at my Stihl's and said to myself, "Na" this just "Can't be "THAT BAD". Well, I guess it was! One for the books. Hey, I'll get'r fixed up and back to order in time! I was looking at parts this morning, does anyone have a guess the year??? I'm sure they are much the same clutch? Oh, for the record, I don't have the vacuum tester but I do have a compression tester. It has very good compression.
  7. WeldrDave
    Gonna make that happen! :yes:
  8. MikeInMa
    I believe the year would is listed on that badge, close to the handle.
  9. WeldrDave
    I'm gonna take the handle off today later. It's crudded up and I can't quite read it! Too small.... :whistle:
  10. M2theB
    M2theB
    Central Massachusetts
    If you can’t read the serial number, pull some of the plastic and look for the manufacturer time stamp
    It’ll look like a clock about 3/8 in diameter and have stamp indication of the month possibly a year in the middle, 02 for example
  11. brenndatomu
    The more it sits (or gets run) with the Startron in it, the better it will get. Still might need to tweak the adjustment screws though...
  12. In the Pines
    In the Pines
    get some mechanic in a bottle, follow the directions on it.
    Can't hurt before rebuilding/replacing the carb. It either will work or won't.
    I love my 350's haven't really had to do much to them. replaced oiler on the one. Never had to mess with the muffler bolts.
    Plastic intake is good so far but I know they are a trouble area on these.
    B.Brown, T.Jeff Veal, M2theB and 2 others like this.
  13. WeldrDave
    So I just got finished cutting the grass! "Yes"! April 2nd and I'm gonna go figure out a few things with the saw. But I think my friend may be going a little :loco: :crazy: He said to me, (That was the original chain). Well, by looking at the 100 sharpenings on it :eek: and the way that clutch looks, He's losing his marbles! In fact, That "can't possibly" be the original bar either. It had some ridge on the bottom I filed out but there is seemingly no wear and very little paint gone. Well, I'm gonna blame it on, "he just forgot". :whistle: I hope I'm not that bad at 67. :p:drunk: Either way, I'll have some more to post later...
    The Wood Wolverine and MikeInMa like this.
  14. WeldrDave
    The moment has came! Ok gents here's the tag! Am I to guess 2004 or 2000?
  15. In the Pines
    In the Pines
    I was wondering who was mowing their yard already.. Man you got all year to get it in.. :hair:
    WeldrDave likes this.
  16. WeldrDave
    Couldn't help it!!! We had places half way to the knee... :headbang:
    T.Jeff Veal and MikeInMa like this.
  17. M2theB
    M2theB
    2004 Id say
    I think the 38th week
    5339th made that year.
    I think that's how that's read
  18. WeldrDave
    Well, I'm no husky mechanic and Thank you all for the help! It came apart fairly easy. It would be in my best interest to get everything including the bearing. Am I correct here?
  19. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Yes, get a new drum AND bearing, they’re often sold together. Never seen a spur sprocket worn that bad
  20. Sandhillbilly
    Sandhillbilly
    Just as well take a closer look at the worm gear for the oil pump while you’re right there also
