Ms 310 sprocket
Discussion in 'Chainsaws and Power Equipment' started by Eckie, Dec 30, 2019.
  1. Eckie
    Eckie
    Think i need to replace the sprocket on my 310. Vids look easy enough to do myself, though I'm not much of a mechanical diy'er usually.
    See various sprockets online....should i get one from stihl/dealer, or are there good non-stihl options that anyone can recommend? Any to stay away from? Any other tips or advice? Thanks
  2. M2theB
    M2theB
    Central Massachusetts
    Welcome aboard.
    It’s not that difficult. Hardest thing is the clutch removal.
    Why do you think you need to replace it?
  3. Fifelaker
    Fifelaker
    Fife Lake Mi.
    No need to remove the clutch. Pop the E-clip off and replace the clutch drum with this and next tine just replace the rim.
  4. Eckie
    Eckie
    Its pretty grooved. I'll try to get a pic and post sometime. I actually meant to do that this weekend to see what people advised, but the seasonal activities took over....
  5. dall
    dall
    West Virginia
    when you get ready to put the new one on make sure you get the arm of the worm gear into the little slot in the drum
  6. M2theB
    M2theB
  7. Meche_03
    Meche_03
    Missouri
    I would stick with Sthil or Oregan brand. I've used some farmtech from hutzl, and they have been good half the time. Half the time they were out of round so bad they couldn't fit into the saw.
    I always replace the clutch drum bearing too.
  8. Eckie
    Eckie
    Finally remembered to take a pic of sprocket when i was home...
    Time to replace? I need to look at bar too, probably time for a new one, may be why there's multiple 'gouges' in sprocket?
  9. dall
    dall
    West Virginia
    ive seen worse but yes id change it
  10. Meche_03
    Meche_03
    Missouri
    Yes. It's time for a new sprocket. You have 3 groves on each tooth. Not only is the drive Link touching the sprocket teeth but the top link/connecting bars are cutting into it.
    Your chains will wear out faster. Sthil chains have a wear indicator on the bottom of the tooth link. Normal bar wear usually won't kill a chain on the link bottom but extra sprocket contact will.
  11. Eckie
    Eckie
    Fifelaker said "yup, inboard atihl, my mistake"... What does that mean?
    Ah so thats what the 'side' marks are.. Does that just happen over time, or is there another issue going on that causes it?
  12. dall
    dall
    West Virginia
    normal for spur just needs changed and would be better to go with the rim drive
  13. Eckie
    Eckie
    Is that what Fifelaker posted above?
  14. dall
    dall
    West Virginia
    yes when you change it to rim drive the next time it needs changed you just have to change the sprocket and not the whole clutch drum
  15. Eckie
    Eckie
    Ok thanks. The one Fifelaker posted has two rims included so that's a plus
    Screwloose, Woodsnwoods and fox9988 like this.
  16. Eckie
    Eckie
    Finalky ordered the sprocket, putting it on. Have what seems to be a problem. It came with a bearing, but the bearing is bigger than the original. The issue is the "length"...it is a bit long, so once i get the washer on I cant get the clip on. Cant use the old bearing because hole in the new sprocket is sized for the bigger bearing...
  17. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Will the e-clip fit if you flip the washer over?
  18. Eckie
    Eckie
    Negative, tried that.
    Even tried the old washer...its larger around, but more saucer shaped..the outer edge isnt as bent or 'rimmed' so a more gradual taper. Thinking this would allow the clip to get in there..no dice.
  19. Meche_03
    Meche_03
    Missouri
    Well,. The big bearing appears to be the correct one for that sprocket. It sits flush with the outer surface of the sprocket shaft. Is the clutch drum is sitting correctly with the slot on the oil pump drive arm? For a quick fix I would sand or file the c-clip just a bit thinner to get it on.
    I've done it on drive shaft ujoints to adjust preload when they were replaced.
    Screwloose and Woodsnwoods like this.
  20. Eckie
    Eckie
    Yeah the drum and sprocket fit good, and the slot is right. The problem really seems to be the bearing being a bit too "long".
