I think I’m gonna need a wagon.
Discussion in 'The Wood Pile' started by Sandhillbilly, Mar 24, 2020.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    On Monday I checked out a property that I can cut all I want on. It’s a ranch homestead with multiple shelter belts. Lots of dead and down, and standing dead stuff. Elm mostly, seen a few ash, and won’t bother with any of the cottonwood unless it’s in the way.
    Kinda wet meadow ground, lots of water standing around now so probably won’t work it much till later this summer or early fall if it dries up some.
    So my quandary is that it’s tight quarters (trees are very close together, plus fences) 30 miles away (one way), so I need to get a decent load when I go. But no way to get a pickup & pickup box trailer close to the trees.
    Thinking I’ll probably take my track skid steer and grapple to clean up the down and rotten stuff and make some trails that I can get a 4wheeler and trailer though.
    I’ve been wanting a trailer for my 4wheeler anyway but never had a justified need for one. I know that I could probably use the skid steer to pack the wood out, but it tends to tear up soft ground. Plus I really want a trailer.:makeitrain"
    So show me some pictures of what you have for ATV trailers & what you like or dislike about it. Help me spend my money wisely
  2. Ronaldo
    Ronaldo
    Brother and made this one. 80 in. long and 50 in wide. Works well with UTV or ATV. Hauls quite a load if you choose. In the process of building another at the moment (I'm isolating for 14 days at the request of my employer).[​IMG][​IMG][​IMG]
    Hinerman, metalcuttr, dahmer and 16 others like this.
  3. Sandhillbilly
    Sandhillbilly
    Is that 50” wide in the bed? Or axle width? Looks a good bit wider than the ATV
  4. Ronaldo
    Ronaldo
    Bed is 50 inches wide. The axle is repurposed from a Dodge Caravan so it is a bit wider wheel base than the Ranger and quite wider than the 4 wheeler.
  5. Chaz
    Chaz
    Southwestern NY
  6. Woodsman
    Woodsman
    NW CT
    I have used my Polar Mesh 1400 trailer behind the ATV for over a year now. Thing has proven its worth time and time again. 1400 lb rating but I think it could handle more. Could definitely hold more if I build up higher sides. Fairly good capacity otherwise. It tips up and dumps though that’s not the greatest feature since the trailer sits so low. Wide wheel base that’s just slightly wider than the ATV. I cut on our property that’s very hilly and rocky and has narrow trails. Trailer has been great. Glides over anything in its path. It’s light enough that the ATV has no problem with it when climbing the steep sections of the hill but it’s rugged and well built. The company that makes them is top notch, too. The welds that attach the trailer arm to the axle housing broke on me recently. I do put the trailer through some rigorous work so it was likely my fault. But the company sent me replacement parts at no cost to me, no questions asked and had them at my doorstep three days later. With an apology to boot.
    Hinerman, T.Jeff Veal, Chaz and 16 others like this.
  7. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    No trailer to show but Woodman, really love the picture of those cedars!
    T.Jeff Veal, Chaz, metalcuttr and 7 others like this.
  8. Sandhillbilly
    Sandhillbilly
    Thanks. That’s one of the ones I’ve been looking at
    T.Jeff Veal, Chaz, metalcuttr and 6 others like this.
  9. jo191145
    I have a little 15 cu ft trailer but I consider that a toy.
    I use this for moving wood. While it’s not a wagon it sounds like it would be useful in your situation. Pulls the logs out of some tight situations. I personally leave the dead tops and scraps behind and just take the good stuff. With a little thought into the process you can winch up and move multiple pieces at once. Just a thought.
    Hinerman, T.Jeff Veal, Chaz and 13 others like this.
  10. amateur cutter
    Somewhere on here TurboDiesel has a build thread on a walking beam axle atv trailer that's really slick. Calling Tim.
  11. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Dat's som tuff hauler you's gotts der!
    Chaz, metalcuttr, dahmer and 6 others like this.
  12. buZZsaw BRAD
    No more Husky's :rofl: :lol: (unless its a good deal) After all if its a good deal its spending your money wisely, isnt it?
    Chaz, metalcuttr, dahmer and 5 others like this.
  13. JCMC
    JCMC
    Just outside of Shushan, NY
  14. amateur cutter
    Thank you!:yes:
    Chaz, metalcuttr, dahmer and 3 others like this.
  15. TurboDiesel
    Whats up, brother?:salute:
  16. TurboDiesel
    I see you guys found it.:salute:
    Any questions, just give me a shout.:handshake:
  17. Backwoods Savage
    Woodsman and I have close to the same trailer. What really makes this thing nice is the wide tires so you can go through mud and snow nicely. They do make a tandem axle but I don't think they would be necessary for most jobs.
    Another way to do things and do them with a lot less money outlay is to build a dray. The nice thing is you can build it to any size you want and they work nicely for hauling out logs. The one pictured I built for $10. It is small but that is all I needed at the time and it works great.
  18. Ronaldo
    Ronaldo
    A couple pics of the new build in process. Using some pipe (instead of 2x6's) we had left over from building hog gates from yrs back. We will leave the gaps in between pipes open for bark to fall thru and then we have a Ford Ranger bed liner that we customized if we are using the trailer for grain (cattle feed), etc.[​IMG][​IMG][​IMG][​IMG]
  19. Horkn
    I use this one behind my ATV,
    It fits a few rounds in it. 10 cubic feet agri-fab Best $50 used cart I've found. It's got decently wide tires 20200107_132540_HDR.jpg
    If I can get it back into where I need to use it, I'll try the 4x8 trailer behind the ATV.
  20. Jon_E
    Jon_E
    Southwestern Vermont
    Look at the Woodland Mills trailers. They are expensive but appear to be worth it. If I was in the market for one, those would be at the top of my list.
