New chain?
Discussion in 'Chainsaws and Power Equipment' started by mrfancyplants, Jun 14, 2019.
  1. amateur cutter
    If you're way strong handed (like I am ) flip the saw over in the vise to sharpen the opposite side cutters, they'll be more consistent that way.
  2. mrfancyplants
    mrfancyplants
    South Carolina
    The cutting went way smoother today. I still had to do some wiggling to get it to engage at points, but if I hooked the dogs? (Claw at the base of the bar) it really flew through the silver maple. I was about half a tank when I tried some noodling, and that was pretty slow going I thing because the round was a little wider than the bar and I probably should have resharpened at that point.
  3. Smaug
    Smaug
    Lake Toxaway, NC
    Can I use the Husqvarna roller file guide for a 3/8 chain on a .325 chain if I use the correct 3/16th file?
    What about the raker depth guage part of the tool?
    Is there a raker depth difference between a 3/8 and .325 chain?
    Thanks.
  4. The Wood Wolverine
    You can’t cross them. 3/8 chain needs the blue one, .325 is silver.
    They simply won’t fix down on the wrong chain. Link spacing will prevent it.
  5. Nixon
    Nixon
    West Sunbury,Pa .
    Also , be careful when selecting the 3/8ths roller guide . There is also a black one . The packaging isn’t real clear about what it’s for . It’s 3/8ths low profile .
    sam s, James Miller, Smaug and 2 others like this.
  6. Dumf
    Dumf Banned
    Pferd = Stihl 2in1 .
    As said, one set for each chain/bar combo.
    Brainless, fast, in the field touch ups with stump vise, no figuring out serial numbers, does both in one pass, good break time ( Bass Ale preferred ).
    T.Jeff Veal and jmb6420 like this.
  7. James Miller
    James Miller
    Hanover PA
    20200309_085654.jpg I use the husky guides. Blue 3/8 black 3/8lp. Freehand in the woods then throw it in the vice every now and then and line everything back up. Wish I was a freehand filing master but it's just not there yet.
    Smaug, OldJack, jmb6420 and 3 others like this.
