My summers heat 2400 thread
Discussion in 'Modern EPA Stoves and Fireplaces' started by Warner, Feb 16, 2020.
  1. Warner
    So, as I said in the other thread I purchased the stove and it’s in the garage. 5B7C7472-7418-4E57-A039-84029EE0FCB2.jpeg Here’s a look at the firebox D4591B3B-AAF7-4873-9A3B-BE3CF976B4A1.jpeg i pulled it out into the driveway and had the first fire 8C278B45-47AA-4A7F-AC19-24848D0FF7F9.jpeg I’m hoping to have it in the house this week.
  2. Warner
    Not knowing where my wood supply was at as far as moisture content goes I picked up a moisture meter. I pulled the largest red oak split and gave it a wack. Not great but it should work. 15E9C29B-1C59-4B7D-ACAA-4743FCD5B27A.jpeg
  3. Kimberly
    Kimberly
    The Kangaroo State
    Look in your stove at the firebrick. The two firebrick that are in the rear of the stove with the angle should be at the front; no gap in the rear; the angle facing towards the front. Those two bricks should be the first ones in the top row at the front at the door.
    Chazsbetterhalf and brenndatomu like this.
  4. billb3
    In the pic the back corners look awful tight for a full brick.
    It's possible where the bricks go is dependent on the version/construct of the stove.
    With the smaller of the two Smart Stoves the bricks with notches might actually go on the back:
    Maina, Chazsbetterhalf and wildwest like this.
  5. Kimberly
    Kimberly
    The Kangaroo State
    My stove arrived with all the bricks in place. Two bricks on the top row; first brick in the row at front of stove, had an angle like I saw in the photo of the stove and they were at the front of the stove. I didn't pay any attention to those bricks in my stove but when I saw them in the photo I am guessing they have that angle for a reason.
    Chazsbetterhalf likes this.
  6. Warner
    I picked up some stove pipe and a thermometer yesterday. When I went into Home Depot someone asked me if I needed help I said I was looking for stove pipe. He said he didn’t think they had any but had flexible dryer vent:loco: :crazy: I hope he was joking but I doubt it.
    I’m off to the rental place in a bit.
  7. moresnow
    moresnow
    To funny. Not really.
    You sure you weren't at Wait Mart? Sounds like a answer you would get there:picard:
  8. Warner
    FFE38451-93FB-4B71-8F2A-020539278A2E.jpeg The old set up.
    Maina, boettg33, brenndatomu and 3 others like this.
  9. Warner
    9E1620E0-8D30-43D8-8495-A3E4448489F3.jpeg Clean slate.
    Maina, brenndatomu, Marvin and 2 others like this.
  10. Warner
  11. Warner
    As you can see by the stairs behind the stove I don’t care much about code! Please keep the code comments out of the thread.
    Maina, farmer steve, Eric VW and 4 others like this.
  12. Warner
    4410A066-3193-4874-A0E3-4DEE63303A42.jpeg Here it is on the power dolly that made it possible for myself and another guy to get it down the stairs.
    Maina, tim117, Eric VW and 4 others like this.
  13. Warner
    I ain’t never had a stove with a window before. This is pretty cool! 36FC7A81-AF9F-4D3E-A683-F8D6BE55E27F.jpeg
  14. Marvin
    Marvin
    Huntingdon, Pa
    Congrats on the new stove Warner! Its gonna be fun watching your progress as you learn how to run that new beast!
  15. brenndatomu
    Nice...I've never personally used one, pretty simple?
    Initial impressions on the new stove?
  16. Kimberly
    Kimberly
    The Kangaroo State
    Yes, it is like having a fireplace and a stove all in one. I like sitting on the sofa watching the fire and drinking my coffee or cocoa. I often find myself nodding off to sleep it is so relaxing; even better when you have that someone special beside you. Did you see my post about the bricks with the angle corners?
  17. Kimberly
    Kimberly
    The Kangaroo State
    Now to make a bit of a man cave down there; some nice chairs to relax and enjoy the view of the fire.
  18. Warner
    Yeah it was pretty simple, definitely still took two people. This one was pretty beat.
    so far the stove seems to throw some heat! I haven’t really run it hard yet tho. It is certainly different than the smoke dragon.
  19. Warner
    I did thanks.
  20. Warner
    I found the door hitting the draft knob to be quite annoying m. So I pulled it off and stuck it in the vice to flatten it out some. That solved that.
