Woodstock made it rock again!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Backwoods Savage, Feb 8, 2020.
  1. BHoller
    BHoller
    Central pa
    But but but they said it was different. And it is going to last for 20 years because it's bigger
    brenndatomu likes this.
  2. BKVP
    BKVP
    Walla Walla WA
    See you next week...KOP. Anyone in KOP area, 20th @ 7:00 pm, Radisson lobby has great bar, I'm buying...lots of good wood chow to discuss.
  3. Dumf
    Dumf Banned
    Oh my, what hubris ! I once did the COMDEX shows for my company for years. Did I learn how to program or hack by walking the booths ?
    I once went to a toy show, but couldn't build a LEGO house.
    All kinds of what stove "failures" ? Specifics ? Brands and models. What "new stoves" ? Or just smoke ? :smoke:
    Just some real world facts mam. This is a forum for info and sharing. :hair:
    One real industry insider shares his expertise here that assist us whether or not we buy or use his products without any boasting.
    End of story.
  4. Hoytman
    Hoytman
    OH
    I was hoping to hear from the rep in answer to my temp questions.
  5. BHoller
    BHoller
    Central pa
    So no comment on the warranty which started your whole rant?
    The rest of it I clearly said was my opinion based upon seeing the stove in question and my many years of experience in the field working on all types of stoves.
    Buffalo Plaid and brenndatomu like this.
  6. BKVP
    BKVP
    Walla Walla WA
    Sorry, are you asking me?
    There are no 100% consistent correlations between surface temp, cat temp and flue temps.
    Cat temps generally elevate during the increased residence time of low burn rates. (In our units)
    Stack temps usually drop and surface area decrease, except directly above the combustor.
    Low stack temps (250F) after responsibly burning off water in fuel load are common. High end stack temps of 500-600 are also common.
    Surface temps vary greatly depending upon where you take a reading. 600- 700 directly over cat is possible.
  7. Hoytman
    Hoytman
    OH
    I wasn’t looking for any correlation, just wondering what the answers to each were. Appreciate the reply.
    wildwest and BKVP like this.
  8. Dumf
    Dumf Banned
    More TLA's.....what is "KOP". If you're buying, some us may fly out.
    Question for non cat primary air control temps for two Jotuls.
    Jotul Oslo never will go much over 550 F ( top thermometer and IR gun readings even at wide open).
    The Jotul Rangely will jump well over 600F plus with a similar air control at wide open.
    Any explanations ?
    The Oslo is +/- 16 years old. The Rangely is on its 2nd winter. Both flues are straight up through ceiling and roof +/- 24'.
  9. BHoller
    BHoller
    Central pa
    Still waiting for an explanation of how I was wrong on all counts. How it their cat different in a way that will make it last 20 years? How is a warranty that only covers manufacturer or material defect useful?
  10. Canadian border VT
    My cat is generally in use 5,000 hours a year (read 24/7 7 months) a year. Cats work for 2 years. Ideal steel you can throw a dying cat in while stove is hot to clean primary.
    Highbeam likes this.
  11. BKVP
    BKVP
    Walla Walla WA
    KOP is King of Prussia Pennsylvania
    Dumf and Canadian border VT like this.
  12. Dumf
    Dumf Banned
    Too many TLA's .
    Thx BK.
  13. Dumf
    Dumf Banned
    All true.
    So here's what I saw, felt, fondled with the F500 V3 cat: at least 2-3 times the size of most cats. The grids are more open. They "say" it is more efficient and cleaner with a faster "light off" without the damper step.
    Has similare kind of BK and others' thermostatic secondary air.
    Only use over time will tell. It is new. Who knows ? Remember Corning and few other cat manufacturers like Sud Chemie for cats used in many products.
    As for their warranty---" I will love you in the morning". "The check is in the mail." CAVEAT EMPTOR.
  14. BHoller
    BHoller
    Central pa
    So you cant back up your claim that I was wrong on all counts?
    Just because it has larger cells doesn't mean it will last longer. Just that it won't clog easily.
  15. BKVP
    BKVP
    Walla Walla WA
    And you know where Corning and Sud Chemie purchased the substrates? The same supplier as I mentioned earlier.
    Dumf and Farmchuck like this.
  16. Dumf
    Dumf Banned
    Thx Chris. Who knew ?
    But--cats are cats whether for stoves or cars. The chemistry and noble metal substrate is the same. Unless, platinum and palladium are used in a different technology.
    Only difference seems to be that gas engines light off a cat with high temps right away. And vehicle cats are big bucks compared to small wood stove cats.
    That's why my check engine light will stay on ( 2005 SUV ) since the code is a defective catalyst. It's close to $1000. to replace the beast.
    Informative discussion.
  17. BKVP
    BKVP
    Walla Walla WA
    Cats in vehicles have rhodium as well. So the application process of these precious metals is what can be supplier unique. Clariant , formerly Sud Chemie, and Applied Ceramics actually are the two suppliers to the wood stove industry that have proprietary application processes.
    Dumf likes this.
  18. Dumf
    Dumf Banned
    Why are you up so early ? Assume it's Walla Walla time.:)
  19. Maina
    Maina
    Check engine light on will fail annual vehicle safety inspection in Maine so a new cat or vehicle may be in your future. Unless you find some scum to put a $50 sticker on that is. Just FYI...
    BHoller likes this.
  20. BKVP
    BKVP
    Walla Walla WA
    Yes. Flying across the USA today. Delta likes me.
    Canadian border VT and Dumf like this.
