sq grinder
Discussion in 'Chainsaws and Power Equipment' started by chris, Feb 10, 2020.
  1. dall
    dall
    West Virginia
    the durability is what i look for in my grinds as well
    i have alot of chains sent to others and ill let a little speed go to achieve durability and in my videos im usually cutting oak or some other hardwood
  2. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Agree Dall. Especially when you’re sending to someone... I have looked at teeth with a magnifying glass after frozen oak. They’re pretty rough if the angles are too shallow.
  3. dall
    dall
    West Virginia
    789CEEEF-0F60-4E5E-AC03-41FB6C9AF0F2.jpeg 23A65494-F66B-426A-A6AB-557CD94CB950.jpeg
    chain was in Alaska and he cut more after the accident
  4. The Wood Wolverine
  5. dall
    dall
    West Virginia
    lol he said it was covered in snow
    still did some damage but ive seen worse
  6. SOS Ridgerider
    SOS Ridgerider
    Central CT
    dall Dallas, I’m ready to get scientific with it! Lol
  7. dall
    dall
    West Virginia
    lol have you checked your dresser angles ?
    T.Jeff Veal and SOS Ridgerider like this.
  8. dall
    dall
    West Virginia
    hows you sondre ?
  9. SOS Ridgerider
    SOS Ridgerider
    Central CT
    I’m good Dallas. How are you?
    I zeroed it out above the bolt for the swing arm. Figured that would be the best and closest area to measure at relative to the wheel, or should I measure zero on the wheel itself?
    Top plate dresser is at 28.7 degrees relative to the top of the grinder.
    The side plate is at 22.7 degrees.
    T.Jeff Veal likes this.
  10. dall
    dall
    West Virginia
    try taking the side plate dresser to 19 degrees and see how it looks
  11. SOS Ridgerider
    SOS Ridgerider
    Central CT
    Roger that. Lemme’ see here.
    T.Jeff Veal and dall like this.
  12. dall
    dall
    West Virginia
    try on a old chain for testing
  13. SOS Ridgerider
    SOS Ridgerider
    Central CT
    Sorry, my top plate was at 19 degrees.
  14. dall
    dall
    West Virginia
    its the side plate dresser we want to work on the most right now
  15. SOS Ridgerider
    SOS Ridgerider
    Central CT
    Here it is. That’s 19 degree side plate. This is a Raisman chain I donated to the cause of learning.
    D39D9BF2-EB0A-4DC5-A988-F635D10F7EA6.jpeg 5462D017-DB9B-49E2-AF7D-2B7528FEE283.jpeg 39E0BA50-0CA3-4A4F-B45A-1D30383F1E00.jpeg 8268831D-50F7-41E4-938F-590F64A9C440.jpeg
  16. dall
    dall
    West Virginia
  17. SOS Ridgerider
    SOS Ridgerider
    Central CT
    Awesome. The top plate ended up at exactly 20 degrees with this set up.
    I’ll get a chain ground this weekend or something.
  18. dall
    dall
    West Virginia
    the less than stock top angle helps durability
    there was a video on youtube showing results of the different angles ill look to see if i can find it
  19. SOS Ridgerider
    SOS Ridgerider
    Central CT
    This is a fresh one that hasn’t been ground on before. Looks pretty good to me.
    it takes a decent amount off the cutter to get the top plate that shallow. 7DE30C77-E3A8-4844-920A-87B10ED1FAAE.jpeg 26B43390-7EF9-48C3-AD1C-8AF49C671934.jpeg
  20. dall
    dall
    West Virginia
    yes it is changing the angles but once you are there it wont take much from now on
