Harman after a good cleaning
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Tullytown, Jan 26, 2020.
  1. Tullytown
    Tullytown
    North of Phila Eagles.
    Scarey burn time. Well over 450 degrees.
    Russell, ivanhoe and Thor like this.
  2. Tullytown
    Tullytown
    Topped out at 476
    Russell and ivanhoe like this.
  3. TLO03
    TLO03
    Measured how ? Im just curious..
  4. Tullytown
    Tullytown
    I used 2 methods. The red dot lazer tool which i aimed thru the distributer vent holes and a digital meat thermometer which i put in the same holes. Both gave same temps within a couple degrees.
    ivanhoe likes this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    Scary HOT I would say :eek:
    You'll need a fenced perimeter around that beast :smoke:
    What are you burning and at what warp speed do you have your ship set at? :D
    Russell and PelletHound like this.
  6. Tullytown
    Tullytown
    Easyblaze premo softwoods, feed rate#3, set at 73 degrees, fan speed less than half speed. Stove or constant mode. Pellets are quite small so can get away with 2/half feed rate when not too cold out. I am seriously running at half throttle of what the stove can put out. But i know how to contain the beast. Excellent softwoods are key here per heat output in my opinion.plus a clean stove. Talk about scary, have douglas firs i have not used at all yet as winter here has been pretty moderate so far. I don't think the firs will be much hotter but probably Less Ash.
  7. Pete Zahria
    Pete Zahria
    New Hampster
    I usually measure my stove, on the right hand side (looking at the stove),
    a little above center. With a laser..
    I like to know how hot the stove is that way..When it drops substantially,
    I know it's cleaning time..
    Dan
    ivanhoe, D-Mac0211, subsailor and 2 others like this.
  8. subsailor
    subsailor
    Winthrop, Maine
    I pretty much do the same with a stove pipe thermometer on the side of the stove. If I have to start increasing the feed rate to maintain 400*, time for a cleaning.
    ivanhoe, Luneyburg and Pete Zahria like this.
  9. D-Mac0211
    D-Mac0211
    Upstate, ny
    I just read mine with a digital laser thermometer and just above center on the right side I got 588°. I was having a problem with it lighting earlier so I lit it manually but that seems pretty damm high
    ivanhoe likes this.
  10. Pete Zahria
    Pete Zahria
    New Hampster
    Just for the heck of it, I shot mine when it was ramping up
    when the T-Stat called for heat...
    Dan
    ivanhoe and D-Mac0211 like this.
  11. D-Mac0211
    D-Mac0211
    Upstate, ny
    What pellets your burning and what stove?
    ivanhoe likes this.
  12. Pete Zahria
    Pete Zahria
    New Hampster
    Harman P68
    Matra/LG Supers, at the moment.
    Idling now at 314°
    Dan
    ivanhoe likes this.
  13. Tullytown
    Tullytown
    I cant hold my hand anywhere near the distrbution vent for fear of scalding and thats under 500 degrees so 688 seems impossible but i see it on your tool...i don t think doug firs can get that hot. Matras,?? Ok. I just did another test and hit 538 with EZBlaze super premo Softies. Ithink another 150 degrees would melt my p61A. Not doubting you but holy Chri..
  14. D-Mac0211
    D-Mac0211
    Upstate, ny
    Yeah I’m using a mix of either matras and fsu (just to get rid of them) or matras and northern warmth supreme firs. But the matras alone burn awesome. I just started having a problem with my stove where it doesn’t seem to want to light. I had to buy a new piece of glass for it since my son broke it. So I have new glass and new gasket but I’m wondering if I need to replace me burn pot gaskets. I seem to also go through an ignitor every 2-3 years
    ivanhoe likes this.
  15. Pete Zahria
    Pete Zahria
    New Hampster
    Henry's is the same..., we both have 68's.
    Different, decent, heat guns.
    His in a large garage, mine in my basement.
    He runs his pretty much hammer down to heat the big shop.
    It ramps up the same 680's..
    DF's, Matra, LaCrete right up there..
    I think they get up there, and then the stove kicks in and
    says "That's enough boys".. and levels off.
    It won't "overfire"..
    Dan
    (Edit: I should throw some LG's in, and see what they do by themselves..
    And get back to this)
    gbreda, ivanhoe and Luneyburg like this.
  16. Tullytown
    Tullytown
    I forgot that your running a P68 to my P61. 7k difference so heat output would be higher at times. Have to say though that i could not get the same output from matras that i got out of the EZBlaze softies. They just didnt get as hot for me.
    ivanhoe and Pete Zahria like this.
  17. jtakeman
    Dang thats hot! I'd be crankin up the fan speed to spread it around. Which would run the stove cooler.
    ivanhoe likes this.
  18. Luneyburg
    Luneyburg
    Hills of Central Mass
    Hmm will have to try and remember to bring home the temp gun from work to see whats happening on my P68 as I am only toasting Matra's straight up this week.
    Good stovegeek stuff.
    ivanhoe, Pete Zahria and Tullytown like this.
  19. Pete Zahria
    Pete Zahria
    New Hampster
    Where the stove is in the basement.. I like the radiant heat there.
    It is where my computer desk etc. is located
    (and a lounge chair, and tv to watch whatever I want..)
    My convection blower heat, is ducted to the upstairs, so the heat that you think is
    coming out of the stove ports, is not really in the basement.. it all goes upstairs.
    Without the stove being there...
    Basement is ~66°, all radiant..dining room is ~73° all convection..
    The stove does not spend too much time at those big numbers. Only a few minutes,
    then it starts to throttle down..
    Dan
    gbreda, ivanhoe, bogieb and 3 others like this.
  20. dotman17
    dotman17
    Snohomish, Washington
    Ugh. It's time for my Harman deep clean.
    ivanhoe, SmokeyTheBear and bogieb like this.
