Wood splitter pump to engine connector question
Discussion in 'Chainsaws and Power Equipment' started by Chris F, Jan 13, 2020.
  1. Chris F
    Chris F
    Micksburg, Ontario
    I just bought a Honda GX 270 to replace the crappy Briggs engine on my splitter. My problem is where the bracket that connects the engine to the hydraulic pump. The old bracket holes on the engine side were 2 1/2 inches apart like in the picture.
    The new Honda spacing is 3 1/2 inches. The crank on the Honda is also 1" but I got that covered already by buying a new jaw connector with a 1" hole.
    My question is:
    What is the correct term for that steel bracket that connects the engine to the pump? I've looked at the flexible jaw connectors and the Lovejoy connectors but none of them show that bracket and I don't know what the damm thing is called.
    Any ideas?
    Screwloose likes this.
  2. chris
    small eng. Coupling, Mount? title seems to vary with mfg.
    Chris F and Screwloose like this.
  3. Chris F
    Chris F
    Micksburg, Ontario
    Hydraulic pump mounting bracket is yielding some results. My crankshaft is also longer so I'll need a longer bracket as well.
    First thing I'll have to do is bring the old bracket inside and take some measurements.
    Of course I was thinking the old one would just bolt right up :rolleyes:
    Yeah, right.
  4. Tiewire
    Tiewire
    Missouri
    4F17 4-Bolt Gas Engine To Pump Mount
    Don’t know how to add a link, but look this up at surplus center and you should be close.
    Horkn, Chris F and Screwloose like this.
  5. JustWood
    JustWood Guest
    Hydraulic pump mount bracket
  6. Screwloose
    Northern China tool also has them.
    farmer steve, Tiewire and Chris F like this.
  7. Eric VW
    Do you get on the forum via smartphone or laptop/PC....?
    Tiewire likes this.
  8. Tiewire
    Tiewire
    Missouri
    Smart phone.
    Eric VW likes this.
  9. Eric VW
    Ok.
    So, when you’re searching something in a browser, you can typically highlight and copy that address and then come here and paste- no special buttons needed.
    It’s easy with an iPhone, just touch the cursor on the screen and “paste” comes up.
    Don’t know if Android has the same option.
    Tiewire and brenndatomu like this.
  10. Tiewire
    Tiewire
    Missouri
    It’s an iPhone
    Smart phone with a not as smart user!
    Eric VW likes this.
  11. Eric VW
    :D
    Believe me, I’m with you on that!
    :handshake:
    Canadian border VT and Tiewire like this.
  12. Tiewire
    Tiewire
    Missouri
    I’ll figure it out sometime. If not my kid can show me.
    Eric VW likes this.
  13. Tiewire
    Tiewire
    Missouri
    How big is your pump? There are two different pump mounts that I know of. Up to 16 gpm is a four bolt mount. 22 gpm and up is a two bolt mount.
    Chris F and Eric VW like this.
  14. Chris F
    Chris F
    Micksburg, Ontario
    It's 17.5 gpm and if I recall it's a four bolt mount.
    I'll have to wait until the weekend when I can remove the mount and bring it inside. I'll need one another inch longer because that's the extra length of the Honda crank.
  15. triptester
    triptester
    S.E.Wisc.
  16. chris
    or make spacer(s) for the exra length- red neck way cut off shaft. Current bracket / mount , whatever -is there enough material to slot the bolt holes? Course having a machine shop at my disposal means none of this is a problem. between the various mills, grinders,welders dang near anything is possible. trick is to keep it square ( shaft center-line alignment).
    Fifelaker, metalcuttr and imwiley1 like this.
  17. Chris F
    Chris F
    Micksburg, Ontario
    Not enough material. The existing holes are right near the outer corners of the mount. The last thing I would want to do is cut the crankshaft. Maybe if I was lost in the jungle and doing that was my only way out...
    farmer steve and Fifelaker like this.
