Brought home a Champion 27 Ton Splitter - Here's Why
Discussion in 'Chainsaws and Power Equipment' started by FreedomFamilyFarms, Jan 3, 2020.
  1. creek chub
    creek chub
    Va
    Glad Home Depot took care of you. I got my county line on January 1 and had to buy the log catcher separately at a different store and installed it yesterday and it made splitting so much easier
    mat60, papadave, Husky Man and 8 others like this.
  2. Chvymn99
  3. Midwinter
    Thanks for all the legwork FreedomFamilyFarms ! I'll most likely be buying a splitter this spring. The only splitter I've used (other than walt's awesome custom-made beast) has been Mwalsh9152's Countyline. I found it easy to operate, but I'm still thinking about an electric splitter. I'd like to get one that I could pull into the back yard myself.
    mat60, Husky Man, Stinny and 9 others like this.
  4. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I think that for your setup it might be best to set it and forget it. Have a processing area in your backyard. Somewhere in the back left corner probably. That's what I'm going to be doing come spring when I can finally get the area I want it cleaned up.
    mat60, Maina, In the Pines and 6 others like this.
  5. Midwinter
    I think my husband will insist on storing it in the garage. It's handy to split in the driveway, but I've got about 2 cord of rounds in the back yard right now....
    mat60, Husky Man, Maina and 6 others like this.
  6. Eric VW
    Not a bad idea Tim, but I think once FreedomFamilyFarms gets a few cords thru the new Champion splitter, the forum would be better served by a full review in the “Reviews” section-
    Wood Splitters
    :handshake:
    mat60, Husky Man, Maina and 7 others like this.
  7. Mwalsh9152
    Mwalsh9152
    Pelham NH
    The only time mine has ever been under cover is when it was in your driveway. Maybe make a lean to off the side of your shed to keep it under?
  8. WeldrDave
    Sorry, late to this, yes I do have one, Got it on e-bay. I'll find the link... Welcome to the forums also!!! :handshake:
    mat60, papadave, Maina and 7 others like this.
  9. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Just ordered one this morning. $5 on eBay shipped from China. Should be able to install it in a month when it gets here
    mat60, papadave, Husky Man and 10 others like this.
  10. In the Pines
    In the Pines
    I just cover mine with a tarp, keep it in the backyard most of the time. I did keep it in the garage for a short spell but I rather keep my car in there.
    I do take the tongue off it, so it's hard for any thieves to take it away. No chains, no hitch makes it a little trickier to pull out of the yard.
    Also my yard is very wet most of the year so they would probably get stuck if they did try and bring a vehicle back there. Basically they would have to pull it by hand to the front of the house.
    And yes I added an hour meter to mine before I ever used it. It's a very wonderful thing to have and I picked mine up off ebay as well. It is a tach/hour meter.
    mat60, Maina, WeldrDave and 8 others like this.
  11. WeldrDave
    Yeah! I think mine was about the same $. Easy installation, get ya some "heavy duty" 3M double sided stick tape with the foam in-between, the stuff they put on the meter will not grab long and it'll fall off, doesn't have good vibration qualities.
    mat60, papadave, Loon and 12 others like this.
  12. In the Pines
    In the Pines
    I like where you placed that, I used velcro so I could remove easily and stuck it on the air filter housing.
    mat60, Husky Man, Maina and 5 others like this.
  13. metalcuttr
    metalcuttr
    western WA
    By all means, take your splitter (when you get it) in back and finish your splitting there! Then store it in the garage where it will be happy and dry. When, in the future, you bring fresh rounds or have logs dropped off at your famous front yard storage tree, do your splitting there and then you move splits, instead of rounds, to the back for stacking. I hope I have your current scheme correct!
    mat60, Husky Man, Maina and 4 others like this.
  14. Midwinter
    You nailed it!
  15. JCMC
    JCMC
    Just outside of Shushan, NY
    I got the heavy splitter cover POC with my DHT splitter it was good for the first month then it started to deteriorate now it is mostly shredded it rips easier than paper I have gone to the blue tarp with bungies.
    mat60, Maina, WeldrDave and 5 others like this.
  16. Mwalsh9152
    Mwalsh9152
    Pelham NH
    $100
    mat60, Loon, Husky Man and 7 others like this.
  17. Midwinter
  18. Stinny
    I think it's called a trailer dolly.
    mat60, papadave, Husky Man and 4 others like this.
  19. Mwalsh9152
    Mwalsh9152
    Pelham NH
    This!
  20. Kimberly
    Kimberly
    The Kangaroo State
    There is a guy in Poland that builds a pretty impressive electric splitter; shipping costs may be a problem though.
    mat60, Midwinter, Husky Man and 2 others like this.
