Fiskars' Return Policy
Discussion in 'Axes, Mauls, and Hand Saws' started by LumberJacked, Dec 26, 2019.
  1. LumberJacked
    LumberJacked
    New Jersey
    I know I'm nitpicking here. Does anyone know the return policy on jacked up points? Has anyone dealt with this before? It's an X27. 1st pic is a nail. 2nd is barbed wire.
    Please advise. Thank you FHC!
    Chaz and Chazsbetterhalf like this.
  2. brenndatomu
    Jacked up points?
    Just dress the edge with a file and get back to splitting...a new one will look the same in a few days too. :axe:
  3. B.Brown
    B.Brown
    USA
    Mine looks the same way, clean it up with a file, and get after it again.
    yooperdave, metalcuttr, Chaz and 6 others like this.
  4. In the Pines
    In the Pines
    ditto, mine looks the same, hit it with a file and move on. It doesn't affect splitting.
    yooperdave, metalcuttr, Chaz and 5 others like this.
  5. unclefess
    unclefess Guest
    same nicks here ,no problem
    yooperdave, metalcuttr, Chaz and 3 others like this.
  6. ironpony
    ironpony
    Mid Ohio
    how is that a warranty claim ? you, unintentionally, tried to cut a nail.
  7. LumberJacked
    LumberJacked
    New Jersey
    I agree it's not. Just wondering what everyone's take is. As for warranty claims. I hope they are all unintentional. Burn on.
    metalcuttr, Chaz and Chazsbetterhalf like this.
  8. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Mine looks way worse than that and splits just fine. I really need to file it good, but when it’s work well no big deal. No warranty issue when you hit stuff you shouldn’t.
    yooperdave, metalcuttr, Chaz and 2 others like this.
  9. unclefess
    unclefess Guest
    if you actually break it and send in a picture they will replace it ,so yes they do honor the warranty ,i know someone who did it ,and i think buZZsaw BRAD did it to
  10. WeldrDave
    Ditto on the blade dings!!! :whistle: Part of the CSS!
  11. buZZsaw BRAD
    Mine looks the same as well. I dont try filing the nicks out as it happens too often and too much filing. Just enough to put somewhat of an edge on it. I did get a new one after it broke back in March as unclefess said. see thread Broken F iskars!
  12. billb3
    Yeah, a couple nicks is kinda normal/usual. As long as the majority of the leading edge is good I wouldn't even try to file them out. They're NBFD.
    Now when you've got 20 nail gouges it's probably/might be time to hit the grinder and remove some metal.
    The first cut is the deepest.
  13. B.Brown
    B.Brown
    USA
    You know after reading this, i was so pumped i went out and mashed the big Fiskers 8lb Isocore splitter into a nice round of red fur. I realized you don't have to put your ''every thing '' into it, just let the weight of that 8 pounder destroy the block of wood. The pure momentum is more than enough to split about any wood, although there are some exceptions to the rule, lol Now i'm wondering if i really need the 27'' splitter to go with my 36'' splitter?
  14. Cheepbeer
    Cheepbeer
    NW Ohio
    Sharpen it! It's regular maintenance. If they have to send you a new one every time you dull yours, they'll go broke.
  15. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    :headbang::doh::picard::hair::faint::(:mad:
  16. yooperdave
    Those nicks are nothing! Heck, even a steak knifes have serrated edges for their cutting. :D :handshake:
    LumberJacked, Ron T and WeldrDave like this.
