Swear Word!
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Dec 27, 2019.
  1. The Wood Wolverine
    If it spun even a little, I'd say a reverse drill bit @ slow speeds.
    Maina, Husky Man, dingbat and 12 others like this.
  2. M2theB
    M2theB
    Central Massachusetts
    Sorry, the bolt is for the coil on this saw.
  3. Eric VW
    Ahhh, just zip tie it somewheres....
    there- winner winner chicken dinner.
    I’ll just:picard:for suggesting that.
    :D
    Hope ya get it fixed gooder M2theB :handshake:
  4. Diesel 4 life
    Diesel 4 life
    Kansas
    Ok so worst case if you were to grind a slot into it with a drimel and used a flat head to turn it out even if you cut into the aluminum a lil bit it wouldn’t be the end of the world. There should be enough thread there to hold it anyway. Just loctite it when you put it back.
  5. M2theB
    M2theB
    My thought exactly
  6. Warner
    If the glue doesn’t hold and you are anywhere near Leominster I’d be happy to give it a shot with the welder if you like.
    Maina, Husky Man, dingbat and 10 others like this.
  7. M2theB
    M2theB
    Thanks!
    I’m not too far from Leominster. 3 or 4 towns, depending on which way I go.
    I’ll keep you posted!
  8. Chvymn99
    :popcorn:.... some good ideals to put in my bag of tricks...
  9. amateur cutter
    Yeah, cause why should they pay us to fix mfg screw ups right? I charge .5 hr for corroded fastener removal, 1hr per broken fastener. The time adds up in a hurry when you gotta heat & beat every freakin steel bolt going into an aluminum bracket/head/block etc. All vehicles only live in the desert SW where nothing rots or corrodes them according to the "book". Sorry, rant over. Glad ya quit, I know I am.
    Maina, Warner, Husky Man and 5 others like this.
  10. Felter
    Felter Banned
    chicago
    all my ideas have been posted already. except this one: on my ford v-10 exhaust bolt i tried to weld a nut on technique. worked 95% of the time. the 2 bolts it didnt' work on I went in with a torch and heated the steel and blasted out the bolt. something about cast aluminum dissipated the heat. even saved the aluminum threads.
    I've tried to cut cast steel with a torch. it took as long as torching steel braided cable. (gotta heat each individual strand) the plasma cutter on the other hand will blast right thru.
  11. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    I would sharpen an M6 screw to a point then tig weld it to the broken bolt. I use this when I can’t use the nut technique.
  12. Horkn
    I have had a lot of luck using that method. However, when I swapped the engine in my Suzuki TL, the broken off exhaust stud would not budge even after I welded and broke off 2 nuts. ( Lol, but seriously) I then had to drill it out, and helicoil it.
  13. billb3
    So, have ya gotten unscrewed yet ?
  14. M2theB
    M2theB
    Not, just got back from a mission.
    A couple hours I’ll hit it with the benzomatic and see if the glue works
  15. RabbleRouser
    RabbleRouser
    In the woods, New Hampshire
    First, start cussin up a storm. Not too much to begin with, start small and build dramatically. At some point begin flinging hammers and such across the shop, if at all possible, breaking other things in the process. Aiming for the crescendo, start threatening the lives and families of Engineers everywhere & talking in an odd, demonic voice about burning the whole shop to the ground. When that doesn't work, jump in the car and lay wheels for a good two blocks down the street. At least that's the way dad used to do it.
    dingbat, Chvymn99, Midwinter and 14 others like this.
  16. Casper
    Casper
    Have any alum (pickling spice) in the cupboard? You could dissolve it if you have some time.
  17. Brandon Scott
    Brandon Scott
    Got a friend like that. Fixed a toilet with a hammer once....
  18. Screwloose
    My nephew to a capital T
  19. Warner
    I’m still working on cars just not flat rate it’s glorious! And the people I’m working for are happy not to have to get screwed by a dealer or independent.
    love the “book” comment. When did a book ever fix anything!
    dingbat, Maina, Chvymn99 and 7 others like this.
  20. brenndatomu
    One time I "shimmed" the leg of a rolling desk up temporarily using a book when the wheel broke off one leg...:D ;) :p :salute:
