Swear Word!
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Dec 27, 2019.
  1. Warner
    M2theB if you don’t have a mig welder now you have a good reason to add one to the tool kit!
  2. brenndatomu
    9 years plus at a bike shop (thin aluminum engine castings) dealing with "I broke this off, can you get it out?" (and only charge me $5 was usually the next thing they said :headbang:) has me very much in agreement...unless OP has no welder, and no access to one...at that point you need to move on to plan B...welding a nut on was/is always plan A...
    dingbat, Horkn, Felter and 9 others like this.
  3. The Wood Wolverine
    Here’s my recommendation.
    I’ve used them successfully many times.
  4. Warner
    That was part of the reason for leaving the dealership. The company that I worked for refused to pay more time for broken fasteners. The manufacturer is using smaller and lighter bolts with locktite that would break bolts in a blink. If flat rate included time to heat all fasteners before attempting to remove them it would be no prob but it didn’t.
    Husky Man, dingbat, Horkn and 8 others like this.
  5. Screwloose
    Why I guess I did didn't I. I have a real dislike for them. I remove about 6 broken easy outs for customers a year. Plenty of better options available.
  6. Screwloose
    Any standard twist drill can be hand ground to cut in reverse, granted it'll be a little negative sorta like a brass/scraper drill. But it will actually transmit a fair amount of torque to the fastener.
  7. Screwloose
    Honestly I never even thought of trying a mig. I will have to try that.
    Husky Man, dingbat, Horkn and 9 others like this.
  8. brenndatomu
    Yep, lay a nut on there and just squirt it full of weld, remove bolt. :D
  9. Screwloose
    I am stuck in tig world.....Godda git out more I suppose.
  10. billb3
    6 out of how many didn't break ?
  11. Screwloose
    No clue. Around here they seem to be avoided like the plague. I typically remove over a hundred broken fasteners a year by more reliable means.
  12. Screwloose
    Not saying that they can't work just I find them risky is all.
  13. Diesel 4 life
    Diesel 4 life
    Kansas
    If it didn’t bottom out before it broke there is no pressure on it and it should just turn out. Use a sharp punch and tap on it counter clockwise till it spins out.
    This is the smartest guy I know. Not really. But you can learn a lot. Just don’t watch if you have sensitive ears. :hair:
  14. Nixon
    Nixon
    West Sunbury,Pa .
    If you aren’t real warm and fuzzy about drilling and extracting that , drop by a machine shop ,and see what they can do for you .
  15. M2theB
    M2theB
    Central Massachusetts
    All great supportive ideas! Thank you!
    And I may end up going through all of them before I go cigarsmokingzombie technique and wrap the thing a hundred yards away.
    This saw is haunted. I’ve been working on it off and on since the spring.
    I took my $30 Christmas gift card up to TS, not enough for mig welder, and bought 5 bux in glue.
    I over torqued it on rebuild, so it not seized on rust.
    I’ll wait the 24 hours, go down to the bench and snap it off with a T27 and go to step 2.
    With the tools I have, I think billb3 will be the next option on my bench.
    At 4mm OD on the threads, there’s not a lot of meat there.
  16. Diesel 4 life
    Diesel 4 life
    Kansas
    What does that bolt do?
    I’m not familiar with that saw.
  17. brenndatomu
    If that bolt was just over torqued and snapped off, then unless the threads started to strip/jam too, it will likely back out pretty easy...maybe with that "glue" (that's a big maybe) or chances are better that it can be "pecked out" with a sharp center punch and a small hammer to encourage movement...just centerpunch a spot close to one edge...then peck at that spot to try and get to turn CC.
    An automatic centerpunch works really well for this too...as long as the bolt doesn't turn too hard.
  18. huskihl
    huskihl
    I know what you meant
  19. M2theB
    M2theB
    This saw is a short lived unicorn MS280. I got it in a pile of saws and appeared to be straight gassed. Solenoid was bad. On rebuild I fworded the air dams. I was going back with new seals when this happened.
    Thanks!
    I’ve put more effort into this one than most and I appreciate the help!
    I’ll report back on the glue Hail Mary
  20. The Wood Wolverine
    Lol! Best answer material.
