Teach me about Pine
Discussion in 'The Wood Pile' started by sirbuildalot, Dec 16, 2019.
  1. Midwinter
    OK, I will report back.
  2. Midwinter
    So, here's how it went...
    A smaller round split with my small wedge. I went down the middle and not the side because there were knots on both sides. Anyway, it split easily. I just had to add a bigger wedge to get it apart completely. IMG_20191219_40657.jpg
    With this big trunk butt, I couldn't get a wedge started on the edge of the round. IMG_20191219_48123.jpg
    It eventually came apart with several wedges. Forget to take a pic with the wedges in. IMG_20191219_9149.jpg
    So, in conclusion, it was a easier to split smaller rounds when frozen, but those big chunks don't want to come apart in any weather. And I got nowhere with my splitting axe, above or below freezing.
  3. MikeInMa
    Your splitting axe might work better now that the chunks are smaller.
    And no. No, there is no dis-honor to chain sawing a kerf first. :)
    Horkn, Chaz, Maina and 1 other person like this.
  4. BigPapi
    BigPapi
    The hills of Western MA
    Might have to wait until it gets cold for a bit first, Midwinter. Wait for that week or two in January or February when it stays around 0 with night time negatives for a few days. That fresh sap takes a while to get solid in my experience, especially fresh off the stump.
    Horkn, Chaz, Maina and 2 others like this.
  5. Midwinter
    Then I have a date with the pine, next polar vortex!
  6. Midwinter
  7. MikeInMa
    Midwinter - do you have an outside fire pit/ring? That pine will smell good burning there, if you do.
  8. Midwinter
    No fire ring. I figure I'll use it for kindling. With a name like pitch pine, it's got to be good.
    Buffalo Plaid, Horkn, Chaz and 2 others like this.
  9. WeldrDave
    Midwinter, there is going to be about 12 "tons" of pine up on my land and another 20 tons come spring. There is that big Ba$T@rd we cut down in the fall, "go get it"! :rofl: :lol: All yours! Some of that was 28" in diameter, bring some wedges and maul. :yes: You know the one... :)
  10. Midwinter
    Oh, yeah! It's just that I'm bored, and this is right across the street.
  11. MikeInMa
    If/when she heads back to your new place, it won't be for pine
  12. WeldrDave
    Yeah, there's only about 50+ more sugar maples and some beech to take! o_O
    Midwinter, Horkn, Chaz and 2 others like this.
  13. Horkn
    Ummm, on this site, it's a regular occurrence.
    Go to the smokehouse section. You'll see a lot of butt comments that involve sir mix a lot.
    Midwinter and Chaz like this.
  14. Horkn
    Are you meaning gray pine? :zip:
  15. Chaz
    Chaz
    Southwestern NY
    Anyone have any input on hemlock??
    I've got plenty of it, as well as some pine.
    Midwinter, Horkn and billb3 like this.
  16. billb3
    About the same as pine just a lot less sap. Given a choice between the two I would take the hemlock. I usually put the two in the same stack.
    Horkn and Chaz like this.
  17. Midwinter
    I like hemlock, as Bill said, a lot less sap. 15.3 on the BTU chart. It splits easily into nice regular splits.
  18. hovlandhomestead
    hovlandhomestead
    MN
    I cut spruce and balsam off our land after it falls on our trails, starts to shade our gardens, or is in the way when making trails. We burn it all too, after at least a year of splitting and staking it. No problems for daytime heating, shoulder season wood, or campfires, along with our ample stacks of poplar for same.
    Chaz, Horkn and Midwinter like this.
  19. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    Midwinter drain that pool and have the neighborhoods biggest fire pit. You wouldn't have to split them quit so small then.
  20. Kartman
    Kartman
    Mineral CA 96063
    Not all Pine should be burned in wood stoves. We have Bull Pine in my region which not only is pitchy but as it burns creates a creosote which can plug up the flue & actually build-up enough to burnout the pipe itself. Ponderosa Pine can contain pitch streaks which can burn excessively HOT. What burns well are the limbs of Sugar & Ponderosa Pine...
    Midwinter likes this.
