I got a leaner!
Discussion in 'The Wood Pile' started by cigarsmokingzombie, Nov 23, 2019.
  1. Marvin
    Marvin
    Huntingdon, Pa
  2. jo191145
    Have powder, will travel :) :)
  3. buZZsaw BRAD
    It would be too funny if one of the chickens was named Adrian!
  4. buZZsaw BRAD
    no powder although id like to see it at your place someday. Ill post thread on leaner when i fell it
  5. Winston
    Winston
    Maryland
    Can we call you Paladin? :dex:
  6. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    Picked up 2lbs of a tannerite knock off today...guy said it works “all the time”. My regular gun shop was out...wtf! Either way, here’s my checklist:
    - leaning tree-check
    - explosives-check
    - day off-check
    - turkey in BGE-check
    - Tavor X95-check
    - 556 ammo-check
    - drone-check
    - wife permission-check
    - golden monkey-check
    Looks like I’m set, what say u?
  7. Winston
    Winston
    Maryland
    A rake for all the kindling you are going to make.
  8. buZZsaw BRAD
    -EMT's/911 on speed dial! :rofl: :lol::pain: Sounds like you're gonna have a blast!
  9. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    Cell phone live comment-check
    Post of video on FHC-check
  10. Horkn
    So this is going down tomorrow? Do you have an accomplice with all that equipment that needs to be run?
  11. bert the turtle
    bert the turtle
    someone has to say it: too little explosive is probably as dangerous as too much. A little extra might send the pieces flying farther or it might blast it into smaller bits and small bits of wood aren't going to fly that far. I really have no idea which. But too little and you end up with a tree half blown up, still hung up- then what's the plan? I'd be drilling and filling to make damm sure that tree is transected. I'm not talking about total dumbassery like 50 pounds, and I'd have some kind of reasonable cover just in case the "smaller bits" theory is completely wrong.
    And it wouldn't be entirely unreasonable to rig the hackberry also. That way if the oak is hung up, you can "safely" drop the hackberry from a distance.
  12. bert the turtle
    bert the turtle
    Another thought: rig it a little way up if you "safely" can. That will give it a better chance of falling out of the hackberry. If you blast it too low, it is going to end up just as hung as if you cut it.
  13. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    The plan is to rig the smaller hackberry. It’s only about 8’ in diameter and already bent from the weight of the oak. I’ll take closer pics of the setup before detonation. Whoooood!
    Sent from my iPad using Tapatalk
  14. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    Good point. I haven’t decided how far up to rig, but can’t go too far in case we miss the target. That would not be good either :)
    FatBoy85, Chaz, Chvymn99 and 8 others like this.
  15. buZZsaw BRAD
    FIFY
  16. MikeInMa
  17. jjspierx
    jjspierx
    I am so excited for this.
  18. Ron T
    Ron T
    Northeast Ohio....Bowdil
    :pete:What time is the event?
  19. amateur cutter
    You better believe I'm in!:popcorn:
  20. DaveGunter
    DaveGunter
