Whitfield Advantage II T C Freestanding smoke smell in room
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Robyn, Nov 8, 2019.
  1. Robyn
    Robyn
    CT
    :hair: Let's hope!!!
    ivanhoe, wildwest and imacman like this.
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    NO SUCH THING AS AN ISSUE THAT CAN'T BE FIXED....:thumbs:
    ivanhoe and wildwest like this.
  3. Robyn
    Robyn
    CT
    That is so true and words I live by, much to my children's dismay . . .
  4. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Robyn...
    Have you lifted the trivet ???
    I have had shells fall through the trivet and smoke when the stove gets hot.
    Could you have a couple pellets laying in that area making a stink ?????
    During filling the hopper its easy to have a pellet or two fall into the slots.
    Or a missing screw that holds the top to the fire box top....
    ivanhoe, jtakeman and wildwest like this.
  5. imacman
    imacman
    Denver, NC
    Robyn sounds like a good thing Snowy is suggesting to check into, since you can't seem to find smoke source otherwise.
  6. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Here a while back... a late night fillemup resulted in getting some shells down under the trivet...about half hour later I am not quite asleep and I smell smoke .
    Stumble out to investigate and it took a bit to discover the trouble.
    Lifted the trivet and scraped out the offending materials.
    Still skunked up the house though...
    ivanhoe, wildwest and jtakeman like this.
  7. Robyn
    Robyn
    CT
    OK, I cleaned under the trivet. It had lots of black sooty stuff on it. Took multiple washings to make it clean. I will hold off on taking apart the top until I test everything I have already done with the new fan assembly. Fan coming tomorrow sometime so I will report back once it is installed and tested.
  8. Robyn
    Robyn
    CT
    Update - I installed the new fan, fired up the stove and still have a faint smell in the back of the stove but it is NOT smelling in the room and NOT making soot on my furniture and seems to be burning properly so I am letting it go . . . Sending a photo. The glass is a little dirty so the flame looks a little different in the photo than in reality, plus I am a terrible photographer! Thanks to all of you for your support. You are awesome and I am warm and cozy again!
    imacman, 343amc, Dpopps and 3 others like this.
  9. wildwest
    Hooray!
    imacman and ivanhoe like this.
  10. subsailor
    subsailor
    Winthrop, Maine
    If you can still smell smoke, there is still an issue.
  11. wildwest
    Robyn what is that black edging on your hearth? I have a similar one and two attempts at wood have been stepped on or broken otherwise, your's looks nice.
    ivanhoe likes this.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    I don't see a surge protector for the stove, It would be wise to get one. Here's a recommended one
    imacman likes this.
  13. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    I get a tiny whiffffff of smoke smell at the rear of mine off and on...usually after a vent scrub with the brush and an LBT
    Can't smell it in the room.
    A pin prick will do this.
    In many cases its like searching for Eldorado.
    Robyn
    Did you remove the trivet and check for a pellet in that area ????
    Also check for missing screws that go into the combustion area.
    ivanhoe likes this.
  14. imacman
    imacman
    Denver, NC
    :yes:
    ivanhoe likes this.
  15. imacman
    imacman
    Denver, NC
    She said she removed & cleaned under it.
    ivanhoe likes this.
  16. Robyn
    Robyn
    CT
    I checked and double checked everywhere that was suggested, siliconed every seam, replaced the fan, cleaned it thoroughly, took apart the pipes, cleaned them and reassembled them and siliconed them. If there is a pinhole, I can't find it. I have a glass table sitting right next to the stove that I am watching to see if it gets black sooty stuff on it. Day 4 and still perfectly clean and the fire is burning beautifully so I am going to ignore the faint smell for now and see how it goes. It bugs me that I can't find the source but I have to let it go for now!
  17. Robyn
    Robyn
    CT
    Not sure what you mean. Where is the black edging you are referring to?
    wildwest and ivanhoe like this.
  18. imacman
    imacman
    Denver, NC
    She's asking about the black edging that goes around the hearth ("base") that your stove is sitting on.
  19. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    The hearth "Frame" is likely a steel angle
    Most commercially produced hearth pads use a steel frame.
    A couple pix
    1/8" X 1-1/2" X 1-1/2" Steel angle (A common material used for the frames of hearth pads.
  20. Robyn
    Robyn
    CT
    Yes, it is angle iron
    ivanhoe, imacman and wildwest like this.
