NC30 fan control extension
Discussion in 'Modern EPA Stoves and Fireplaces' started by capetownkg, Nov 17, 2019.
  1. capetownkg
    capetownkg
    southern, MD
    Holy cow I haven't been on here for quite a while, I hope everyone is doing well. I have a quick question looking for some ideas and a solution.
    I have a nc30 slammed into a brick fireplace with the larger blower on it. However due to putting it back in the fireplace I cannot access the controls once a fire is started. How would I go about making an extension to run a switch outside the fireplace? I'm not the most electrical savvy person so excuse the simple question.
    Thor, Marvin, papadave and 1 other person like this.
  2. papadave
    Good idea. Having to reach around behind a hot stove to adjust the blower isn't ideal, but at least I can reach mine.
    Do you turn it on and just leave it on all winter?
    Oh, welcome back. :yes:
    wildwest and Chvymn99 like this.
  3. chris
    simple way is to set fan to high speed then plug it in to a remote AC speed control unit which is nothing more than a SCR variable light dimmer for the more diy inclined persons.
    wildwest and RGrant like this.
  4. capetownkg
    capetownkg
    southern, MD
    Ok so do you know what kind of amps it would need to be able to power the fan? Seems simple enough as long as I get the correct one
  5. capetownkg
    capetownkg
    southern, MD
    I have it plugged in to a surge protector and when it's not needed just cut the power, or if the stove is cool I can adjust the fan just a pain in the butt.
    papadave likes this.
  6. papadave
    I have a snap disk from the old stove I'd like to wire into this blower, but have no idea how to do it.
    Worked pretty well on the old stove.
  7. chris
    snap disc in series on one line, does not matter which side.
    Off hand amperage wise just the common SCR dimmer control by itself would be sufficient I would highly doubt that it pulls more than 3 amps.
