Tools of the trade or your inventions
Discussion in 'The Wood Pile' started by T.Jeff Veal, Oct 2, 2018.
  1. webby3650
    webby3650
    8 cords ain’t all that bad! I’ve got endless amounts of standing dead oak for future use. I hope that at least helps qualify me as a hoarder.:confused:
  2. brenndatomu
    8 cords is a nice stash...and standing dead Oak qualifies as vertical firewood storage...just razzin ya a little. ;) :D :handshake:
  3. webby3650
    webby3650
    I can’t walk at the moment and haven’t been able to for a week or so. Otherwise I’d be in the woods cutting.
  4. brenndatomu
    Uh oh! :pain:
    Well, heal up/feel better soon! Those trees will wait (for a while ;))
  5. Erik B
    Erik B
    Western Wisconsin
    T.Jeff Veal Stlshrk I have a 25T Speeco splitter with the wedge on the ram. I got tired of trying to pull pieces of wood apart when the wedge didn't go all the way thru. Using a piece of wood as a backer to allow for a full split usually ended up with a backer that would fall apart.
    I have a friend whose step-son is a logger and he had a bent up stake off one of his logging trailers. My friend cut a couple of pieces of that metal stake about the height of my wedge. We found some angle iron and cut a couple pieces the to match the first metal pieces. I had a spacer between the two channel pieces originally that were bolted together. I kept the space between the two channel pieces far enough apart to allow the front edge of the wedge to fit between them with the ram fully extended.
    When I finally got around to having it welded up, a place was added to the other side of the angle iron that would allow it to slip over the base of the beam. Here are a bunch of pictures I took of this project. First 4 pics are of the original version that was bolted together. The rest of the pics show it all welded up.
    DSC00793.JPG DSC00794.JPG DSC00795.JPG DSC00796.JPG DSC01245.JPG DSC01246.JPG DSC01247.JPG DSC01597.JPG
  6. Woodyone
    Woodyone
    Massachusetts
    image.jpg image.jpeg image.jpeg Home made articulating 4 wheel drive Case tractor.
    My best friend, John too. John Deere is my main firewood tractor. Home made 3 pt logging setup with a 8000 lb hydraulic winch.
  7. T.Jeff Veal
    Very nice sir. You have some skills. Welcome to the club, lots of great folks here sharing knowledge and humor. What other equipment do you use? Stove, saws, splitter? What's your stacks like, favorite wood? How long have you been burning?
  8. Woodyone
    Woodyone
    Massachusetts
    6DAE462E-0C8B-478D-8098-E56AC1DC2890.jpeg Husky 372 is my main firewood saw, have some
    Older Saws for backup. Latest addition is a 56 volt Ego chain saw for quick cleanups plenty of power to cut fair size logs as well.
    Main splitter is a home built vertical with a log lift. Table about 4 ft x 6 foot set at waist height.
    Case tractor has a vertical splitter as well, smaller cylinder, mostly for in the woods work.
    Home made wood stove, been using it for about
    25 years. Been heating with wood for 45 years, going to be 70 years old soon.
    Split lots of my wood with a Fiskars splitting axe. Got about 15 to 20 cord ahead most of the time.
    Vertical splitter pics are construction pics. DE320FBD-FD88-4C76-A8E3-ED609B200475.jpeg 072B00AC-29D0-4D0F-AB13-AFC86CF71D62.jpeg
  9. Midwinter
  10. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Welcome to the club, not only are you gonna like it here, I already like having you here. That little case setup is pretty nifty! :yes: Was it a trencher or something in its former life?
    T.Jeff Veal, Screwloose and Stlshrk like this.
  11. Woodyone
    Woodyone
    Massachusetts
    Case tractor was just a regular hydraulic drive front steer tractor. Used another Case 2 speed rear end and made an articulated frame to connect them. The Case tractors are hydraulic drive, no belts no drive shafts. Steering is with a hydraulic cylinder. Also has high output and low pressure hydraulic take offs. Rear bed unplugs and a logging arch butt plate slips in with a hydraulic winch. A vertical hydraulic capstan winch is mounted in front of the box bed to haul in small trees etc.
    The frame also swivels to allow the tires to stay flat on the ground at all times..
  12. Sandhillbilly
    Sandhillbilly
    Sweet!!! That’s about the handiest rig for wooding I’ve seen
    Rush Battle and Midwinter like this.
  13. T.Jeff Veal
    Did a few upgrades to the 30 ton Countyline splitter. We plan on only using it horizontal if possible.
    First, we added angle iron bracing for the log table. 0405201415_HDR.jpg Then made leg supports for table and ramps 0405201515.jpg 0405201534.jpg Being able to load up ramps, really speeds up the process 0417202020a.jpg
    Then we had some stringy hickory and elm to process, we added stacks of flat bar to the foot, so blade can go past end of the round. 0813201027.jpg
    Today, I got a hatchet to chop strings on big rounds, wanted it to be handy. Used a piece of flat stock and a U bolt, made a hanger on the end of the foot. 1016201941_HDR.jpg 1016201942_HDR.jpg 1016201942a_HDR.jpg
    Stlshrk, Erik B, MikeyB and 10 others like this.
  14. Timberdog
    Timberdog
    Az
    Awesome:yes:
    MAF143, buZZsaw BRAD and T.Jeff Veal like this.
