Old Haulers
Discussion in 'Chainsaws and Power Equipment' started by MrWhoopee, Apr 13, 2017.
  1. MrWhoopee
    MrWhoopee
    Shingletown, CA
    Walstib!
    I'm not familiar with a "barley crank", is that used in beer making? roflmao2.gif
    This has taken quite some time, I hope you finally get it sorted.
    Chvymn99, Horkn and bang like this.
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    The timing may be a bit to advanced, that can make em crank hard when warm
    bang, clemsonfor and Horkn like this.
  3. Horkn
    Here's my classic wood hauler 35 years old, going on 36 in spring.
  4. Kevin in Ohio
    Kevin in Ohio
    Bought this old 3/4 military Dodge for the combat rims. Stuck motor, no brakes, broken winch and beat hard. It was used as a woods truck to drag logs before I got it. Started piddling with it and got it to run. Kept the overhead gas tank for a conversation piece but it does work!~ LOL Beat the dents our and put some better seats in it. Good enough to beat around in and I have a spare motor now when I do a resto on my 1/2 ton WC.
    These above are how it was when I got it.
    Quick body work with a sledge hammer.
    Good enough to haul some loads out from here at the farm.
    DNH, Need2Saw, Chvymn99 and 10 others like this.
  5. pa.forester
    pa.forester
    Berwick, PA
  6. pa.forester
    pa.forester
    Berwick, PA
    1986 F250
    460 engine
    4:10 gears
    Boogeyman, Chvymn99, Stlshrk and 2 others like this.
  7. clemsonfor
    Chvymn99 and Horkn like this.
  8. clemsonfor
    For those who have not seen recent pics of my old "Brown truck" I will post some here.[​IMG]
    Sent from my moto g(7) using Tapatalk
    Boogeyman, Thor, Need2Saw and 4 others like this.
  9. pa.forester
    pa.forester
    Berwick, PA
    I went to Penn State Mont Alto for Forestry, worked on a USFS hotshot crew for 3 years, and then ended up as a Land Manager for the state. Not the traditional forestry jobs I once envisioned, but am happy with the journey I’ve been blessed with.
    I love my job...& my trucks!
    Need2Saw, Chvymn99, Horkn and 2 others like this.
  10. clemsonfor
    I'm sure you can tell from my name where I went:D Go Tigers! I work in the public sector in Timber sales. PM me if you want to know more. I am more secretive than some, there some weird people on the internet, and you never know who lurks and reads and what their intentions are. I am easy enough to find for someone determined but I don't want to say who I work for here cause there are not many of us and one of me in the state.
    That is a cool Ford. One of my best buddies in college had the same body style, early 90s, it was crew cab long bed sitting on 35s. Took a football field to turn around.
    Horkn likes this.
  11. Kevin in Ohio
    Kevin in Ohio
    I guess my 89 makes the 30 year cut off now. The mighty 1/2 ton has hauled hundreds of cords over the years and keeps going. getting close to 300,000 miles on her now.
  12. OhioStihl
    OhioStihl
    Southern Ohio
    Nice!
    Horkn and clemsonfor like this.
  13. OhioStihl
    OhioStihl
    Southern Ohio
    Does it sit level when it’s unloaded or is that it’s natural stance from years of service? 350?
  14. Kevin in Ohio
    Kevin in Ohio
    It does sit level when it's not on the stops like that. Squat is not for looks like kids are doing now. LOL It does have the 350 in it. Both heads have been replaced at different times due to cracks. First time I did it I went ahead and pulled the motor out to replace the rear main seal and figured it would be a good time to replace the oil pump. When I pulled the pan off bottom end was as clean as a pin. ONE paper towel cleaned the pan. says a lot about REALLY changing oil every 5,000 miles. that was at about 150,000 miles. Never broke a spring or frame. Have replaced the rear axle but that was at 125,000 and that was before I started using it for a hauler. No issues with axle since.
  15. clemsonfor
    Your pics still impress me. Those are full cords!
    Need2Saw, Horkn and Kevin in Ohio like this.
  16. eatonpcat
    You gotta quit babying that truck, put her to work for goodness sakes!!
  17. clemsonfor
    Yea some people don't get the oil thing?? I change oil in all my stuff religiously. In vehicles that don't make that Mark they get an oil change every year.
  18. eatonpcat
    Love your truck!!
  19. Kevin in Ohio
    Kevin in Ohio
    Most of these cord loads never went on the road as they are from the homeplace. I do run close to cord loads on the road and just take it easy from farm to farm. Used to running loads with weight like that as when I worked on the farm we had a 500 gallon spray rigs on 2 different trucks and had 6000 lbs over the rear axles on nearly every load. Did break a frame in one of those one time. Spring breaks too as bouncing over plowed fields was hard on them.
    Need2Saw, eatonpcat, Horkn and 2 others like this.
  20. MrWhoopee
    MrWhoopee
    Shingletown, CA
    Now we're talkin'! Those are some good old trucks doing what they were meant to do.
    Answering the question "Can you really put a full cord in a standard bed pickup?"
    That truck needs some side racks, then you could really load it up.
