Brushed flu
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, Nov 1, 2019.
  1. bogydave
    Not bad for a year :)
    Most is from the cap.
  2. Locust Post
    Dry wood cannot be beat.
  3. bogydave
    :thumbs::thumbs::thumbs::thumbs::thumbs:
  4. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Huh. If you saw what came out of my old flue system, you'd think I was cleaning every chimney in the canyon ! :rofl: :lol:
    New pipes are breathing much better, no buildup. Hope it looks like yours when time to clean, Dave.
  5. bogydave
    Not sure why, but the chimney cap
    gets some of creo
    & inside the stove behind the metal
    shield gets creo.
    Real dry wood , maybe the oil & wax in the birch bark???
    But the Chimney’s good & clean
  6. Horkn
  7. Beetle-Kill
    Beetle-Kill
    I get the same build up behind the shields, we discussed using that Simpson strap to clean it out. My old Class A was so poorly designed, I can't believe the house is still here. New Class A and a much improved smoke path should alleviate the problems I had before.
    Backwoods Savage, Eric VW and Horkn like this.
  8. Beetle-Kill
    Beetle-Kill
    I'm going to stand on the roof and do that. ;)
  9. Horkn
    Could be from the birch bark. I get a little too at the cap, but I think that's mostly due to me not trimming back the top of the liner to be flush with the bottom of the cap. It does obstruct flow a little.
    I keep telling myself that I should bring up the grinder and just do it when I sweep the chimney.
  10. shack
    shack
    Upstate NY
    Never thought of using a purple sled under my clean out...you might be on to something there.
  11. bogydave
    It was handy,
    usually use a cardboard box.
    Backwoods Savage and Horkn like this.
  12. billb3
    Interesting, my cap stays clean.
    Most of the resideu is much closer to the stove.
    Horkn and Backwoods Savage like this.
  13. Horkn
    My liner is not insulated. It's a 6" ss liner in a Terra cotta flue. I've got a feeling that this minor issue would be solved by dumping a bunch of insulation down the Terra cotta flue. That would keep the pipe temps from dropping much.
  14. billb3
    There might be a brushed shot for that.
  15. Ctwoodtick
    Ctwoodtick
    Southeast ct
    I hate to be a Debbie downer, but it looks like you swept a child’s sled out of the flue. Usually this means wet wood, lol
