Stihl 034AV question..
Discussion in 'Chainsaws and Power Equipment' started by Chaz, Oct 13, 2019.
  1. Chaz
    Chaz
    Southwestern NY
    Ok, so I put the Stihl to work today.
    :saw:
    Thing runs great..
    Once it's running.
    :doh:
    From a cold start, I've gotta pull that thing at least 30 times.
    :faint:
    Once it's been running, first or second pull & it's fired up and ready to rock.
    :dex:
    This can't be normal is it??
  2. clemsonfor
    Have you adjusted the carb? Fresh fuel? Any concern that compression might be low?
    Sent from my moto g(7) using Tapatalk
    M2theB, Chvymn99, Eric VW and 2 others like this.
  3. Chaz
    Chaz
    Southwestern NY
    Have not adjusted carb.
    Fresh fuel put in today.
    Haven't checked compression, don't have my own tester.
    We got this saw through the raffle for leadfarmers daughter. I generally run the Poulan as it starts pretty easy.
    But, I wanted to use it today.
    Once running, can't ask for a better saw, but getting from cold start to running is a bit irritating.
    M2theB, Chvymn99 and Eric VW like this.
  4. clemsonfor
    I bet after adjusting the Carb it will start easier. Where did it come from, just curious. Altitude and temperature differences can make perfect settings not so perfect in the new location.
    I would say turn the L screw out a half a turn and see what it does for you.
  5. huskihl
    huskihl
    The choke linkage isn't closing the butterfly completely. Bend it a little straighter and it'll push it further
    MFMc., eatonpcat, blacksmith and 6 others like this.
  6. Chaz
    Chaz
    Southwestern NY
    :yes:
    Took off air filter, and yes B'fly valve was still open a bit, tweaked it, 6 pulls to a run.
    I will be adjusting the carb some, but glad it starts in less than a dozen pulls.
    Thx guys
    :cheers:
  7. Chaz
    Chaz
    Southwestern NY
    Previous owner is down in DC area.
    Will definitely be adjusting carb some.
    :handshake:
  8. Eric VW
    Less yankin’ on your shoulder always gooder!:salute:
    Glad y’all chimed in- I would’ve been zero help.
    :D
  9. Chaz
    Chaz
    Southwestern NY
    Yeah, no need to be worn out before the saw is running.
    :faint:
