MS261 oiler question
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Oct 8, 2019.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    Sometimes the paint wears off of them quickly.
    Chaz, Ou812, Woodsnwoods and 2 others like this.
  2. JotulYokel
    JotulYokel
    Missouri
    I've got an MS251 that I bought a year ago. It also doesn't seem to sling any oil except at WOT. But the oil resevoir goes down in sync with the gas resevoir, and I took it into my Stihl dealer and he said it was oiling just like it is supposed to. I don't think mine has an adjustable oiler.
  3. SAWMIKAZE
    SAWMIKAZE
    PGH
    7/32 is way too much file for .325 chain.
    I use a 13/64 on a .325 chain with more tooth to get the gullet a little better and then 3/16 as the tooth wears.
    Chaz, Woodsnwoods and T.Jeff Veal like this.
  4. The Wood Wolverine
    Any pics? I agree with the lack of hook and I don't think simply not tilting will cure it.
    You only want a small amount of the file to be above the top plate.
  5. buZZsaw BRAD
    its my understanding only pro model saws have an adjustable oiler. Both my 261 and 460 do and my 290 doesnt. This will be the first time ive adjusted it.
    Chaz, T.Jeff Veal and Woodsnwoods like this.
  6. buZZsaw BRAD
    using 3/16 file. Didnt need the sharpening, but fourth time its been sharpened.
    Woodsnwoods likes this.
  7. huskihl
    huskihl
    Everything in red should be filed down to the tie strap.
    Blue shows your cutter angle. Lower the whole file to create more hook like the yellow line
    10° down angle on the file handle is a good thing. It makes the working corner stronger and the outside of the cutter sharper to help self-feeding.
    Heres a pic of a good cutter to try and mimic
    Chaz, bear 1998, MFMc. and 9 others like this.
  8. huskihl
    huskihl
    I think 290's have an adjustable oiler.
    Chaz, bear 1998, T.Jeff Veal and 4 others like this.
  9. buZZsaw BRAD
    i honestly never checked
    Chaz, bear 1998, T.Jeff Veal and 2 others like this.
  10. buZZsaw BRAD
    my old .325 16" Oregon chains had a good hook like that and i was using a 7/32 file to sharpen. I could file "deeper" I sharpen free hand using only the file. I decided to buy some 3/16' files and use the correct size.
    Is the pictured tooth hand ground or machine?
  11. huskihl
    huskihl
    The pictured cutter is from a grinder, but it's the same for filing. The proper file size will require you to file the gullet after sharpening the cutter. You shouldn't be able to reach both in a single pass
    Chaz, bear 1998, T.Jeff Veal and 3 others like this.
  12. SAWMIKAZE
    SAWMIKAZE
    PGH
    This.
    huskihl, T.Jeff Veal and Woodsnwoods like this.
  13. farmer steve
    farmer steve
    top of the hill york co. PA.
    Mine does not. Not sure about the old 029 super.
    Nope,double checked before I hit post reply.:picard:
  14. buZZsaw BRAD
    Checked under my circa 2010 MS290 and this looks like an oiler adjustment farmer steve IMG_1088.JPG
    Thanks for the sharpening tips huskihl .:yes: Just when i though i was a decent hand sharpener too!:picard: I turned the oiler screw up a tad and noticed the stream of oil was better.
    Dumb question...If one tops off the bar oil and gas then runs the saw til its out of gas. How much oil should remain? Basically how much oil per full tank of gas. I understand there are variables...bar length, temperature etc.
    Chaz, bear 1998, farmer steve and 3 others like this.
  15. The Wood Wolverine
    If your oiler is turned up the whole way 1 to 1.
    I agree w/ Kevin’s post above. That’s what I was getting at asking for another pic. I think it’ll get you on the right track.
    With extra force being placed on the bar, it heats up the rails and the paint fails. Since I’ve kept my chains crazy sharp, my bars retain the paint mich longer.
  16. T.Jeff Veal
    Yep, that's the oil adjuster. Our 029 is adjustable.
    Chaz, bear 1998, huskihl and 2 others like this.
  17. farmer steve
    farmer steve
    I think mine is a bit older (1992) Brad but now I'll look again. Most of my Stihl's are about 1/2 tank of oil to a tank of fuel. YMMV.
    Chaz, buZZsaw BRAD and T.Jeff Veal like this.
  18. farmer steve
    farmer steve
    I was wrong.:picard: My 290 does have the AO. Hard to see the hole in the handle. Not the same place as my other saws.
    Chaz, huskihl, bear 1998 and 2 others like this.
  19. buZZsaw BRAD
    T.Jeff Veal said his 029 has one. Not sure when Stihl went from the 029 to the MS290. I had a circa 1993 026
  20. Erik B
    Erik B
    Western Wisconsin
    T.Jeff Veal I have an 029 super and I haven't seen any oiler adjustment. Where is it? :handshake:
