Time for replacing the ceramics in the Wood Gun gasification boiler.
Discussion in 'OWB's and Gasification Boilers' started by Gasifier, Sep 26, 2019.
  1. campinspecter
    campinspecter
    Those bubbles help moisture escape as the refractory cures. ( looks like green or uncured refractory)
    Gasifier, brenndatomu and Eric VW like this.
  2. Eric VW
    That may be so, but in my experience of pouring refractory parts, it also shows a lack of sufficient vibratory action.
    fuelrod and Gasifier like this.
  3. Gasifier
    Alan. Do you think it should be warmed with several small fires. Then increasing the size of fires slowly to help the curing?
    campinspecter likes this.
  4. Gasifier
    Are you speaking of ceramic refractory or concrete? Same?
  5. brenndatomu
    I used to work at a steel mill and they would reline the huge ladles that the molten metal was poured into kinda often...they used a very dense firebrick in those...but I was told that the curing process on those is very detailed and needs to be carried out precisely...I think "aeriated" refractory offers a little more fudge factor for the "retail public"...
    campinspecter, Need2Saw and Gasifier like this.
  6. Eric VW
    No. Refractory.
    Defined as not concrete(Portland cement).
    Gasifier likes this.
  7. nsmaple
    nsmaple
    Nova Scotia Boonies
    That's what I would do.
    My first couple of fires had water dripping out the front. Scared me a little bit. But it didn't last long, and the originals are still in there. Cracked in a couple spots, but starting onto season 8 with them with no (well, not much) worries.
  8. campinspecter
    campinspecter
    It won't hurt . Going from room temp , to 2000 F in several minutes can have a very large expansion factor .
    I make my own nozzles ( each is about 40 lbs) very dense 3000 degree refractory . Before they are installed each get cooked in the kitchen range oven going from a 170 degrees to 550 degrees in 50 degree increments allowing for a half hour for every 50 degrees ,this process really stinks .Then when placed in the boiler I do five burns using 3lbs of fir kindling and 2 hours for each cycle . My home nozzles far out last the factory ones .
    cnice_37, Gasifier, nsmaple and 2 others like this.
  9. Gasifier
    New blanket piece here and everything installed.
    A7538DDE-57BB-4566-AB4B-8F13E4B4F3A6.jpeg 06D90ACE-605A-4940-9783-BE8072B08BE6.jpeg 3FB3FBFE-C47B-4667-95B2-58FACA5E614C.jpeg 65AFCC2E-CFB4-4194-8AE3-568C812255D0.jpeg
    Everything seems to fit okay. Not perfect, but fairly close. Now to decide what I need to use the trowel-ease on. But first a short break for a little caffeine and breafas!
  10. campinspecter
    campinspecter
    brenndatomu and Gasifier like this.
  11. Heat550
    Heat550
    Minnesota
    So every 9 years they need to be replaced ? How much did new set cost ?
    Sent from my LGL84VL using Tapatalk
    Need2Saw and brenndatomu like this.
  12. Gasifier
    New full set of ceramics with new blanket and new nozzle bricks were $1300! :doh::picard:Oh well. In eight seasons I’ll save about $24,000-$28,000 in fuel oil cost. My boiler heats my large house, attached garage, and domestic hot water.
  13. brenndatomu
    Holy moley! :eek: :faint:
    I would have been making a cast of those puppy's so I can make my own next time!
    Canadian border VT and Gasifier like this.
  14. campinspecter
    campinspecter
    Sounds like a good price!
    The complete refractory for a Jetstream in 2011 was $ 1600 fob Turo, Nova Scotia
    It weighed around five hundred lbs.
    High density refractory is heavy and quite expensive and Gasifiers' would be very complicated to form. IMGP3372.JPG
  15. Gasifier
    I know a guy who spent a LOT of time researching and making his own replacements. They didn’t work out very well.
    brenndatomu and campinspecter like this.
  16. Canadian border VT
    Gasifier, yes its hard to swallow that big maintenance expense. I find it odd that we complain about maintenance on our heating devices. But furnaces that use oil or Nat. Gas have similar maintenance costs.
  17. Gasifier
    slowly warming the boiler up. :fire:
  18. Gasifier
    Wood Gun Gasifier is running smoothly. The colder it gets the smoother it seems to run.:thumbs:
  19. lukem
    My boiler runs way better in the cold too.
  20. Locust Post
    I have never experienced a gasifier but I know my stove burns extreme!y well when it is really cold outside. This was an interesting thread.
