Think she'll hold?????
Discussion in 'Modern EPA Stoves and Fireplaces' started by bear 1998, Sep 15, 2019.
  1. bear 1998
    bear 1998
    S.C.Pa
    Added 3 ft. of Class A pipe today..
    My transition plate was put into a break n all 4 sides were bent 90* s.....drilled 2 holes on each side....welded stainless nuts into place with stainless cap bolts.
    Ran a thick bead of high temp locktite adhesive around the top of the terracotta flue n transition plate....
    Think it'll hold ??
  2. The Wood Wolverine
    That’s lookin’ good!!
  3. Chaz
    Chaz
    Southwestern NY
    Very clean install.
    :yes:
    Like that spark arrestor, very nice.
  4. papadave
    That spark arrester looks like something out of Mad Max. :dex:
    I'd lose it, and get a more open design. JMHO Sure is shiny.
  5. Chaz
    Chaz
    Southwestern NY
    You hush, I like it
    :binoculars::cool:
  6. Chaz
    Chaz
    Southwestern NY
    On second thought
    :sherlock:
    papadave is correct, you should get a more open design one and send that one to me for disposal purposes.
    :D
    :handshake:
    It's like a Cylon sitting on the roof.
  7. Backwoods Savage
    I think that spark arrester will work out okay.
    btw bear 1998 if it don't work, you'll always know that it should have. Did the wife help?
  8. bear 1998
    bear 1998
    S.C.Pa
    She was my gopher for a couple things....she climb the ladder but not get on the roof.....
  9. brenndatomu
    Dat oughta hold...shore looks gooder anyways! :thumbs:
  10. moresnow
    moresnow
    Nice job. Can only assume you guys will certainly know if it falls off. Steel roof. CLANGo_O
  11. billb3
    Looks stout enough to survive a Fall or two, maybe even a fall or two.
  12. brenndatomu
    CLANG screeeeeech...thump! :rofl: :lol:
  13. bear 1998
    bear 1998
    S.C.Pa
  14. bear 1998
    bear 1998
    S.C.Pa
    Next week ill spread crown sealer on......ill post a few pics of that...
  15. ReelFaster
    ReelFaster
    S.Jersey
  16. Horkn
    Install looks good. My spark arrestor looks very similar, except mine has screening inside of the slots too.
    That crown sealer works great, and looks great too. I sealed mine last fall.
  17. My IS heats my home
    My IS heats my home
    Albany, NH
    Great looking install! That new SS looks so pretty, make sure you give it a buffing when your up there for your flu cleanings.
    Which reminds me, I have to get a new brush for my flue. :whistle:
  18. T.Jeff Veal
    Looks great, brother. I don't think you will have any problems with it falling off.
  19. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Looks good,did you need more draft?
  20. bear 1998
    bear 1998
    S.C.Pa
    I really think so....too damm warm for a fire yet....besides its screwy here...had a better draft when its warm than when its colder.....i really think its because we are on southern side of our mountain n the wind n pressure plays an effect...but i feel itll be better...leave ya know in time !....had to try it....
